corednc
- Sep 3, 2019
- East Coast
I am trying to backup a fanuc 21-TB to an SRAM card but I am getting a 930 CPU Interrupt error whenever I try and format the card or write to it. I have two different cards and I get the same error with both. Research on this issue seems to indicate that the problem is generally an error with the memory in the machine but I think that is not the case since this happens when I try to just format the card and otherwise the machine runs fine.
Does anybody have any insight into this issue?
Does anybody know of any other method to do a full backup (settings, parameters, ladder etc.) of this control without an SRAM card? The machine has a serial port but I have no idea if this is possible and what the key strokes would look like.
I would like to try another SRAM card but I can't just keep buying new cards because they are expensive, so if there is anybody who has an SRAM card that works on a Fanuc 21-T and is willing to part with it for a week or so, I would appreciate it. I have an OmniDrive SRAM card reader that can read the card and copy the files to a PC, so in exchange you can backup your machine to the card and send it to me and I will copy the files and send them back to you via email. I will then test out your card on my machine and with any luck backup my machine and send your card back to you. Let me know if that works for you.
