rokstarr999
- Feb 7, 2014
- Sonoma County, USA
HI
The shot pin on the spindle orientation is not engaging so I can't do a tool change. After pushing spindle orientation the spindle will attempt to orient and the shot pin will move in but it will pop back out. The orientation ring will rotate a couple more times as the shot pin pops in and back out until the machine alarms out. If anyone has any tips I would appreciate it. Is it possible the tip of the shot pin sheared off and now its not long enough?
Thank you
Thank you
