leeko
Stainless
- Jun 30, 2012
- Chicago, USA
Hi everyone,
I need to mill a constant depth (~0.040" deep) pattern on the face of an irregularly shaped object which varies in z-height. The shape of the object is essentially a portion of a sphere, but with irregular edges and not with constant curvature.
I have an STL of the object, which I can use to generate the toolpaths for the pattern. I was planning to mill or 3d print soft jaws using the negative of the STL for accurate location of the part on the mill. This works, but is pretty time consuming. I'm wondering if there's a quicker way of doing this?
One thought I had was to use a smaller vise with gripper style jaws that will hold irregular objects. That would work, but wouldn't tell me the orientation of the part (since the grippers will likely skew the part as they grip). I considered using photogrammetry or laser scanning of the part in the vise, then using that smaller vise as the WCS origin, but this seems inconsistent and also pretty time consuming.
Are soft jaws the only reasonable way to do this? I have a couple hundred of them to get through (all slightly different), so anything I can do to speed the process is much appreciated!
Lee
Sent from my SM-N960U using Tapatalk
Lee
