JesusCalfeeDesig
- Sep 24, 2021
I'm trying to machine a part, but it keeps giving me indentation and renders it useless.
At first, there was play in the y-axis play so I tighten the gibs. Now there is only .0005" play.
That didn't solve the issue. We turned the tolerances down to .001 mm. didn't work.
It's only doing a .5mm finishing cut. On aluminum and Delrin on both materials, it gives the same issue.
we checked the code to see if fusion 360 did something weird but it looks good and does the transition how it should.
It's happening when it goes from a straight line into the ark and when it's done with the ark it seems that it comes back to where the line should be and causing another indentation. It's almost as if one of the arks is off-center which is not because everything on fusion is centered correctly and it also appears that way in the code.
I am open to any suggestions Please let me know.
