Acme threading, Mazak T32 - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #21
    Sep 2010
    Oklahoma City, OK
    5,867
    1180
    2610
    Quote Originally Posted by Ianagos View Post
    Btw the poster above that mentioned the zig zag cycle that’s what the highlighted 0 is in mazatrol.
    Well the highlighted options are all different types of zig zag cycles
    Also in my part decreasing the sfm made the chatter go away but I think the other poster is correct about faster speeds being better for the carbide.
    I wish it would let me control the pass count but it auto-populates that cell.
    Programmed via Mazatrol
  2. #22
    Sep 2014
    Georgia
    1,161
    13
    305
    Quote Originally Posted by Cole2534 View Post
    I am fairly confident it will if you change the cycle type.
    You have 2 selected which is where it auto generates the number of passes. Change that to the highlighted 0 and it will let you select how many passes
  3. #23
    Sep 2010
    Oklahoma City, OK
    5,867
    1180
    2610
    AH HA! I'm gonna set this bitch up with like 90 passes.
  4. #24
    Nov 2019
    CANADA
    Ontario
    778
    1342
    186
    Tool was minty at the beginning of the program.
    why is the angle at 29? acme threads aren't like standard 60 degree threads. machine is feeding it sideways as it goes in.
  5. #25
    Nov 2005
    1,599
    19
    204
    Quote Originally Posted by BT Fabrication View Post
    That field requires you put in the included angle of the tread for an infeed angle to match the flank. So 29 yields an infeed angle of 14.5, which would be correct for an acme thread. Some people would prefer to go a little less, but this can cause rubbing and excess tool pressure on the trailing flank.
  6. #26
    Sep 2014
    Georgia
    1,161
    13
    305
    If you look above I posted the page in the manual that talks about it
  7. #27
    Sep 2014
    Georgia
    1,161
    13
    305
    Sometimes my machine will give me an error when I do too many passes. Usually catch it in simulation though.
  8. #28
    Sep 2010
    Oklahoma City, OK
    5,867
    1180
    2610
    OK, back at this and I've discovered the issue. The chatter is causing 2 things to happen.
    1) the material moves back in the chuck. Maybe I don't have the chuck pressure high enough?
    2) the tailstock moves rearward. I put an indicator on the base and it didn't budge a thou during the OD work and most of the threading. Once it got about 3/4 into the thread the chatter picked up and the tail base moved as far back as 1/8" in pass. By then the material had shifted enough in the chuck to ruin my threads.
    This machine has the powered tailstock. Looks like some sort of drive off a hydraulic actuator? Does it have clamping? I've been using M31/32 to move it.
  9. #29
    Sep 2014
    Georgia
    1,161
    13
    305
    Default Acme threading, Mazak T32
    Glad you checked for number 1. I know I mentioned that above.
    As far as number 2. All my machines have always had sub spindles so I cannot comment on the tailstock situation.
    And you possibly put a spring loaded center in the tailstock? I’ve been experimenting with doing this in my lower turret
    Also as far as your Chuck pressure when in the last time you took you Chuck apart and cleaned and greased it? Also what type of jaws are you using? I feel like serrated hard jaws would be best
  10. #30
    Sep 2010
    Oklahoma City, OK
    5,867
    1180
    2610
    I'm using a solid, live center.
    Chuck was cleaned and greased just prior to this part, got hard serrated jaws in it as a matter of fact.
    But, I think the answer lies in that photo- there's no tailstock pressure.
    I did some digging in the mazak forum here and there's a thread on it. Quick Turn 15 Tailstock body slips. Help!
    After reading I followed their diagnostic steps to confirm my TS clamp needed adjustment. I did it, and documented it lightly in that thread, to find that now I have all the tailstock pressure I want. I recut th thread with an indicator on the tail body and it didn't budge.
    Best I can figure is that my threading setup caused some harmonic resonance that helped the tailstock slide back. Once the center was no longer tight the bar went all over the place, explaining my drunken thread.
    Simple fix, even it did cost me a couple days and a hundred bucks in material.
  11. #31
    Sep 2014
    Georgia
    1,161
    13
    305
    So did the threads end up turning out good in the end?
  12. #32
    Sep 2010
    Oklahoma City, OK
    5,867
    1180
    2610
    Yes sir. Good parts came out, about to deliver to the customer this afternoon.
  13. Likes VTM liked this post
  14. #33
    Mar 2019
    Massachusetts
    555
    254
    257
    Good job, I am proud of ya!!!
  15. Likes Cole2534 liked this post
  16. #34
    Sep 2010
    Oklahoma City, OK
    5,867
    1180
    2610
    Quote Originally Posted by DanASM View Post
    Thank ya sir.
    I left out the part where I put a LH top notch insert into a RH holder. Dunno where it went, but it went there with a crash.
  17. Likes TeachMePlease liked this post
  18. #35
    Sep 2014
    Georgia
    1,161
    13
    305
    Thank ya sir.
    Ouch yea you need to use ngr insert not ngl
    I seem to always just have the inserts in the opposite of the side I need
  19. #36
    Feb 2014
    FL
    4,799
    14456
    5897
    Thank ya sir.
    "Did anybody else hear that?"
  20. Likes Cole2534 liked this post
  21. #37
    Sep 2010
    Oklahoma City, OK
    5,867
    1180
    2610
    I have both, but this is purely my ignorance at fault. The shaft has LH and RH threads, so I bought L and R inserts, thinking that they were ground with relief for LH and RH threads. I wasn't thinking that the inserts were for different holders.
    All in all, I can sum up this project as trying too many new things at once:
    First time using the 3j
    First time using the tail stock
    First time using Top Notch inserts
    Not my first threads cut, but 4tpi acme is the most aggressive I've cut.
    Job is done, customer is happy, I made some money, I learned a LOT.
