thunderskunk
Cast Iron
- Nov 13, 2018
- Middle-of-nowhere
Hey gents,
I’m experimenting with Corian for a particular forming tool. My gut tells me both feed and speed should be through the roof for this; something on par with a wood router. Does this sound right? Anybody ever messed with it?
My spindle maxes out at 8000 rpm. If the use case works, I’ll be making a heck of a lot more using this material. I was thinking about using one of those through-coolant speeders. This has even more implications like having coolant filters to keep plastic out of the tank and so forth, possibly swapping out my coolant mixture.
For reference, the stock size is 0.5”x6”x12” and I’m removing about 60% of it. Largest tool is a 3/4” and smallest is 1/8” flat. A few ball endmills for gusset forms. What I’ve got is TiAlN costed carbide but I’m really not sure it’s the right thing either. I’d gander 3-flute HSS might work just as good if not better than my 4-flute carbide I normally stock.
