I have a Haas VF-2 VOPD and want to run a air solenoid off the m code part of the board I have 3 voltages I can use 24vdc 120vac 12vdc when I looked up the electrical manual for another machine the board is separate but it is 12vdc is that what I should run. which draws the most amperage I don't know how much amperage I can get away with air solenoid for 120 psi air. the board does not have volts or amps for this area.
Just a "quick one" / busy day.
Pneumatic Safety Door Interlocks Troubleshooting Guide
If you poke around on the HAAS service section of their website you should be able to find what you are looking for (perhaps).
So for example on the pneumatic door interlocks they use 120 V for those solenoid valves …
"Measure the voltage at the I/O PCB. The correct voltage is 120 VAC. Verify that voltage is present (connectors P29 [1] on a Classic Haas Control (CHC), P40 and P41 [2] on a Next Generation Control (NGC)) when the door is closed and locked. If no voltage is present, go to I/O PCB - Troubleshooting Guide (Classic Haas Control) to troubleshoot the I/O PCB. If voltage is present, test the solenoid. Refer to Solenoid - Troubleshooting Guide to troubleshoot the solenoid."
^^^^ For illustrative* purposes ONLY (the gist) ---> For what you need / approach Higher res versions on the link posted above for "Classic" versus NGC.
Blah blah blah dum de dum de dum…
Not sure more specifically what you are trying to do. There are a few HAAS free-lance service techs / repair "Peeps" that have posted on PM forum in the past.
Generally/ electrically / theoretically the 120Vac will draw the least current, followed by 24 V (DC) followed by 12 V (DC), for the same wattage of device. BUT depends on what part of a board you are drawing from and it's design intent and cross sectional area / rating for set of copper tracks in that part of a board /circuitry.
^^^^ DISCLAIMER don't act on what I have written here until you have verified what you want to do for yourself... I don't want to "Jack" your machine up with incomplete information provided + incomplete "Advice". + Your safety/ competency / experience with electrical power systems.
_________________________________________________________________________________________
* Copyright
HAAS Automation.
@toolfood not sure what you want to do with your M code and what size / type of solenoid you want to use for what specific purpose ? I'm sure there are a lot of folks on PM forum here that can help you / advise you on good combinations of what you are trying to do.
