Hello PM Community,
We just purchased a used Samsung SL2500BY lathe with full C and Y axis capabilities.
We are looking for any pointers, feedback, or advice on how to check this thing to ensure that it cuts what we tell it to cut.
Our first priorities are to check the alignment of the head stock, and then the tail stock.
To achieve this we will take long cuts on a piece of material and measure the straightness of those cuts.
For the head stock, we will take a 15.0" long cut on a piece of 3.0" diameter 6061 aluminum. The 3.0" diameter will be turned, and so will jaws.
The material will be choked up a great deal, sticking at least 6.0" into the draw tube.
We will also face it and center drill it for the following tail stock check.
For the tail stock check, we will use that same piece of material, but pull it out from the chuck, and take a 20.0" long cut holding on to it with jaws on one end, and a live center on the other end.
Once again we will check the straightness of the material after making that cut.
Any feedback or criticism you can offer about our plan is most welcome.
Thank you
Thank you
