Ah-Ha SD124 Stepper controller manual or other help, also for a Bridgeport Boss-II
Likes Likes:  0
Results 1 to 8 of 8
    Aug 2019
    Default Ah-Ha SD124 Stepper controller manual or other help, also for a Bridgeport Boss-II
    HI All
    I have an ancient Bridgeport Boss-II with an equally ancient Ah-Ha control box with just the DS124 controller boards and a BOB connecting them to the PC running LinuxCNC. Been working great, BUT I'd appreciate any help with the following:
    1. Manuals, specifications, wiring drawings for the AH-HA stepper controller boards--and possibly a source for a spare board.
    2. The same for the bridgport mill, the specifications for the stepper motors in particular.
    3. Any information on alternate stepper controller modules that are KNOWN to work with the stepper motors on this mill. The settings on the AH-HA board suggest it is set for 10Amps, but the highest power replacement I can find is a 7A Gecko module.
    Kelly
    Jan 2014
    Washington
    4,189
    778
    2244
    Probably get more help on a different forum like CNC Zone. Not many here work with cobbled together stuff.
    Aug 2019
    Thanks...I've posted there too...just trying to cover ALL of the possibilities.
    Jun 2008
    Dassel,MN,USA
    91
    13
    46
    I ran an AHHA refit on a Bridgeport BOSS 3 in the 90s. The company went out of business back then. So, they've been done 20 years now. Their design was for DOS only and a parallel port to do IO.
    All this stuff is obsolete even for a hobbyist. Time to send it all to the recyclers
    Aug 2019
    AH, but it still works...and I'm trying to find out enough to identify a clear replacement. I know the company is long gone, but I'm hoping someone still has manuals or data sheets. My system has been running fine on LinuxCNC for a year or so...but I do want to find newer hardware.
    As near as I can figure out, the boards are set for 10A (IF they are the DS124) or 5A (if they are the DS64). A 4 Amp stepper driver barely moves them, so I suspect the motors really do need the ten amps--but I'd love to hear from someone who has first hand knowledge of the setup.
    Enjoy
    Kelly
    Jun 2008
    Dassel,MN,USA
    91
    13
    46
    Yep, I'm sure those old BOSS steppers were at least 10A at 48 volt.
    The step driver is going to be maintenance free - when it dies get another.
    For inputs your are going to have 110 VAC or possibly a DC power need.
    There will be a step line coming from the control and a direction line coming from the control. Use a logic probe or look at your Linux manual to determine these.
    You will have two pairs of wires to the stepper. Normally obvious which lines are paired. Since its still running give it a G1 as slow as it will move and check with a VOA meter.
    You are really in the hobby world. Find a web site that does Linux CNC, tons of helpful types there.
    Aug 2019
    Thanks Karl....
    I was afraid of the ten amps...The only new drivers I can find are from Gecko, and they are rated at 7 amps. They offer a full credit return policy, so I guess I'll indulge and try three of them. Stay tuned.
    Jun 2008
    Dassel,MN,USA
    91
    13
    46
    automation direct, for one, sells ten amp drives
