Air spindles
Likes Likes:  0
Results 1 to 9 of 9
Thread: Air spindles
    Aug 2006
    Wisconsin
    1,759
    798
    814
    Default Air spindles
    Does anyone in the house run any air spindles similar to Air Turbine Spindles?
    Aug 2009
    Oakland, CA
    403
    199
    Not currently but I used to have a bunch of Air Turbine 602 spindles and they were generally a disaster. Get an NSK and be much happier NSK
    Oct 2010
    Dewees Texas
    3,252
    35
    1087
    I bought a pair of NSK and used them fairly regularly for several years. Never had an issue with them. They are still here in a drawer and If I used them today I would expect no issues. Never used the Air Turbines so I can not compare them.
    Dec 2013
    1,059
    291
    645
    We used to recommend and install the NSK 50k air spindles before Brother came out with the 27k spindle. Some issues with air spindles are very low torque, you don't know how fast it is actually spinning in the cut, maintenance and reliability issues. After switching to the 27k spindles cycle times went down, tool life, part quality and reliability went way up. No matter how small the cutter or light the cut there is still torque involved to machine efficiently. If you must, the NSK will do ok. If you need a more solid long term solution I suggest looking into a machine with higher rpm capability.
    Jan 2019
    Missouri
    418
    107
    104
    I have used the air turbine tools, Dont remember the model exactly. One of the cheaper ones. Only used it to drill tiny holes. But I drilled what seems like millions of them
    They Worked ok for that
    Aug 2006
    Wisconsin
    1,759
    798
    814
    I should add that I already have a 25k spindle, but the need for smaller tooling comes at me more and more. I need something that I can toolchange with, so that might limit my options.
    Aug 2009
    Oakland, CA
    403
    199
    We were able to make our own arm for the NSK spindles so that it could tool change in a drill/tap machine but it wasn't fun. I'd take a look at the Alberti electric spindles ALBERTI LEONARDO - Koma Precision Incorporated
    Nov 2018
    ALAND ISLANDS
    341
    155
    117
    Another vote for NSK. I think we’ve got 11 just in our cell.
    Jul 2011
    VT,USA
    46
    118
    18
    We switched from Air Turbine Spindles to NSK electric spindles. Worth every penny. They are also toolchangable now
