valterroque
- Nov 13, 2017
Hello
Machine: 2006 Hyundai kia SKT200 cnc lathe/ fanuc Oi-TC
I am slowly trying to make this machine run and after some initial alarms with the fans, tailstock etc (all solved), now it pops up this alarm error.
AL-30 Chuck Clamp NG (the spindle runs but the feed gets hold. only the manual feed works )
The installation Manual its not clear about this alarm as its only printed and no solution is provided.
Searching on the net or in this forum there is a small note about the jaws needed to be in the range as the last operators leave them. but it did not specify how it clears.
The machine arrived without jaws, and i purchase a new hard jaws set from SHUNK. After i installed the jaws, clamped a piece of stock and i tried to command in MDI ex: M3S500 and the alarm pops up.
with the jaws open no alarm
With the jaws close and no stock alarms
With the jaws close and stock pressure alarms.
Can someone give me some indication about how to solve this?
Is this related to some safety parameter?
How can i clear this
Note: I have not tried any programming yet. This is only on MDI.
Some guidance is very much appreciated.
Also note that i have not previous experience with cnc lathes ( i am a square guy).
Regards
Valter
Regards
Valter
