Alcohol as coolant on aluminum
Page 1 of 2 12 LastLast
Results 1 to 20 of 39
    Oct 2013
    New Jersey
    1,080
    897
    Default Alcohol as coolant on aluminum
    I saw a research paper recently that said alcohols reduce cutting forces on aluminum by as much as 50%. I just cut hundred of counterbores on 8020 extrusions and also some 6063 box tubing using alcohol in a fog buster style mister. My machine is a light duty home built CNC mill with a router for a spindle when cutting aluminum. I was pleasantly surprised at how well the alcohol worked. No problem with chip packing or BUE even on the 6063 that has given me fits in the past. I used 90% drug store Isopropyl. Easy chip cleanup as it evaporated so quickly the chips were dry.
    Anyone doing this with real machine tools?
  2. Likes Q liked this post
  3. #2
    Jul 2012
    Washington
    2,805
    1077
    1121
    Interesting experience with the 6063! I have machined enough to know what a PITA it can be. What was the base reference for the 50% reduction in cutting forces? Was it dry or with a coolant?
    Aug 2014
    California, USA
    63
    7
    48
    Yeah, lots of high precision type machines use isopropyl. Datron for example in the US. The oils can get annoying for high tolerance/small tooling type work. For light duty work like your though I would recommend WD-40. I use it a lot on smaller jobs where flood coolant isnt available. It also helps to have lubricity if your tools are worn as it helps a lot with chip evacuation.
    Oct 2010
    Oregon
    5,064
    4284
    1827
    I have used kerosene for aluminum many times. Currently, I use a spray bottle of WD-40 when cutting aluminum on the manual lathe.
    Kerosene (or other light oil) is an ancient recommendation for aluminum. This is the first I have heard about alcohol. I will have to give that a try, as the cooling effect will be huge compared to oil, and I happen to have 98% isopropanol in a spray bottle already.
    Feb 2011
    BFE Nevada/San Marcos Tx
    1,119
    984
    581
    In a large facility, how do they deal with the flammability issue, especially since it is an almost invisible flame?
  7. Likes mc3608, digger doug, Derek Smalls, Dualkit liked this post
  8. #6
    Feb 2013
    Northeast USA
    146
    63
    14
    Curious about how to use it as well. A spray mister maybe? What about breathing in the fumes, or flammability as mentioned above?
  9. #7
    Jan 2007
    Flushing/Flint, Michigan
    7,694
    383
    6417
    Quote Originally Posted by garyhlucas View Post
    I saw a research paper recently that said alcohols reduce cutting forces on aluminum by as much as 50%...
    Post a link. Really doubtful unless against pure dry which would be stupid and brainless.
    Coatings, speeds, rakes, force measured how? Show me this data.
    Bob
  10. #8
    Oct 2011
    CANADA
    British Columbia
    612
    39
    383
    Used alcohol in a spray bottle all the time for 6000 series extrusions and also 5000 series marine plate.... in a large shipyard. It did limit tooth pickup but not as well as saw wax. The problem with saw waxes is that they can contaminate weld joints.
    It was the most practical for using with large hand held routers with carbide cutters, half inch shank. One person running the router and the other pump spraying.
  11. #9
    Oct 2013
    New Jersey
    1,080
    897
    I knew someone would ask where I saw it! I'll have to check. Note that I use a fog buster style mister that doesn't really put out mist but larger drops. I can run the machine all day and you never see any mist in the enclosure. I have used a Spraymist unit in the past and that would fill the whole shop with mist in no time. Very bad for your health I think.
  12. #10
    Oct 2013
    New Jersey
    1,080
    897
  13. #11
    May 2011
    New Jersey
    2,010
    184
    1120
    Fill it with everclear and turn the mist up
  14. #12
    Jul 2006
    Hillsboro, New Hampshire
    7,364
    1736
    5120
    Bob
    I can't give you data, just direct experience from cutting Al spacecraft parts ~22+ years ago using an alky mist to cool/lube the endmills. I can't remember if I came up with the idea on my own or read about it somewhere, but after some simple tests found that it worked well with bare carbide cutters.
    I did some purposeful tests to see if I could ignite the mist with a welding sparker, and never got it to "poof" even with prominent sparks. Didn't try a direct flame, though.
    One nice aspect of working at a university at the time - I had access to reagent grade ethyl alcohol, so if there was a buildup of vapor at worst I'd get drunk rather than poisoned. I guess they trusted me as my supervisors knew I didn't drink. In truth, never noticed any ill effects, but I had a welding hood not too far away that I kept on to help with ventilation.
  15. #13
    Oct 2010
    Oregon
    5,064
    4284
    1827
    Holy cow! That study implies that just writing on piece of Al with a Sharpie is an effective stress raiser. That has implications for a lot more than just reducing cutting forces.
    Also worth noting is that isopropanol has zero effect on Cu or Fe, despite the large effect on Al. On the other hand, various glues and inks (!) were effective on all three metals to some extent.
    Tests were done on material in the annealed condition (soft, gummy). Might not apply to material in a higher temper condition.
  16. #14
    Aug 2012
    California, Central Coast
    3,407
    2167
    1327
    Quote Originally Posted by sfriedberg View Post
    I seem to remember a thread on this, or a discussion in another thread, not long ago. The sharpie sticks in my mind.
  17. Likes TeachMePlease liked this post
  18. #15
    Feb 2014
    Sunny South West Florida, USA
    2,766
    10459
    3193
    Quote Originally Posted by Rob F. View Post
    I also recall that thread, to the point that I scrolled up to check the post date on the OP, to make sure I wasn't reading an old thread again.
  19. #16
    May 2017
    FINLAND
    1,687
    480
    781
    Alcohol (with or without added soap) is ages old cutting fluid for aluminium at least around here. Milk for copper goes to same category.
    I bet not many use whole milk for copper machining on CNC's either
  20. #17
    Dec 2015
    Illinois
    401
    135
    223
    I jokingly mentioned using whole milk for machining copper at work once and was told in no uncertain terms if I filled the sump with rotten milk the whole shop would kick my ass.
  21. Likes TeachMePlease, sfriedberg liked this post
  22. #18
    Jun 2006
    Thunder Bay Canada
    1,807
    565
    304
    As a student I discovered that methanol and acetone worked well for tapping aluminum. One benefit it the rapid evaporation rate that helped the chips fall right off of small taps. It makes sense that these solvents should help cutting forces for milling and turning.
    And also that plain water worked great for Plexiglas.
  23. #19
    Dec 2003
    poulsbo, wa, usa
    725
    36
    298
    I use Alcohol a lot for sawing 6061 and have found spray-n-wash works great for tapping on the Bridgeport ,,, I was using A-9 for tapping but it left spots on my shirts as did WD-40 … I get gallons of Spray-n-wash at Costco and use it on all my manual machines for alum ..
  24. #20
    Jul 2006
    7,364
    1736
    5120
    Quote Originally Posted by D.D.Machine View Post
    That's an interesting choice - any signs of rust? Does it dry clean, or with some sticky leftovers?
