Aluminum chip management
Results 1 to 17 of 17
    Apr 2021
    Washington
    30
    24
    5
    Default Aluminum chip management
    Good morning everyone,
    This is a two part question but I'm hoping there will be some good input even if everything isn't magically resolved.
    Working at a business that has been growing year over year and essentially needs to double production capacity overnight. Looking into adding a robot and/or dual spindle lathe to reduce ops and run afterhours. This means double the amount of chips in an ever shrinking facility.
    I've been researching briquetting machines and have found some that look promising. Unfortunately they all appear to struggle with stringy chips and we end up with one softball sized birds nest from the finish of each cycle. So I looked into shredding machines and they cost as much as the briquetter (or more!).
    Now it appears to me that the problem really starts in the lathe and the shredder shouldn't be necessary if we can fix the birds nest, which I'm assuming could also cause problems with robots or part exchanges in a DS lathe...
    So here are my questions:
    Has anyone made a cheap shredder or have any ideas on how to put something together? And then we have to figure out how to transport the shreddings into the briquetter...
    How can we eliminate the stringy chips altogether? Heavier feed? Switch up the insert? Different rough/finish tools?
    Haas lathes, 6061, parts are 7-11" diameter and slightly convex, CNGG 431-ML K10 insert, 1950 SFM, .005" per rev, .005" deep finishing pass
    I don't exactly have a ton of experience running production so hopefully I didn't forget any vital information!
    Jul 2006
    Hillsboro, New Hampshire
    12,760
    2901
    8831
    Just had a thread on this, check it out:
    Aluminum swarf/chips processing
    Feb 2007
    Sweden
    171
    13
    PCD Insert with chipbreaker turns the stringy balls into dust.
  4. Likes Mtndew, GiroDyno, CORONA VIRUS liked this post
    Sep 2015
    Ohio
    1,734
    1153
    1823
    General consensus is scrap yards won't take briquettes. I did have good luck with getting the scrapyard to drop off gaylords and pallets.
    When I got them full I'd call and they would come out, pick up the full ones and drop new empties and give me a check for the last batch.
  6. Likes AARONT, BT Fabrication liked this post
  7. #5
    Jun 2012
    Michigan
    5,857
    5534
    3738
    Quote Originally Posted by GiroDyno View Post
    I don't know if that chip breaker is doing anything at that depth of cut.
    Maybe try the PCD as mentioned above. One insert corner should last damn near forever.
  8. Likes GiroDyno liked this post
  9. #6
    Feb 2012
    1,582
    972
    1785
    I think briquetting is a distant priority that you probably don't need to worry about anytime soon.
    For now, I think it's figuring out how to break the chip, and making sure your material is consistent enough such that you're not chasing a moving target.
    PCD sounds like a good solution. A tool rep should be able to provide you with tooling on guaranteed test.
    As for material, thick sections are hit-or-miss when it comes to heat treating. If you start seeing inconsistency in material properties (gumminess), you might have to figure out an alternative to off-the-shelf, large diameter rounds. For example, you can try waterjet plate, or send in sawcut discs for heat treating. This all costs money, so you have to weigh the costs vs the benefits.
  10. Likes nicholasnbailey liked this post
  11. #7
    Feb 2016
    Washington
    274
    518
    154
    Definitely try some PCD tools. With diameters that big you can really get you SFM up to where they excel and the chips will be a lot more manageable. Plus they will last forever in 6061. We get over 30 hours of cut time on some DCMW 32.52 inserts at about 7000 SFM with an interrupted cut in A380.
    Walter is our current choice for standard ISO PCD inserts. We originally used Sandvik, but their prices only kept going up. Kyocera offers some with a chip breaker, but we had issues with them failing early. Kennametal also makes them, but I've never thrown the single test tool in a machine to see if it would last.
    For custom stuff look at STF or VR Wesson. We get a lot of PCD grooving inserts through them.
  12. Likes GiroDyno liked this post
  13. #8
    Apr 2021
    Washington
    30
    24
    5
    Thanks for the input I will definitely look into the PCD inserts! Will check out the above mentioned brands and try to get a rep in. We have a few hundred unique part #'s but luckily they're all XS-XL sizes of the same thing so the right tool should take care of everything.
    We fill chips in drums with holes to drain but it takes an operator or two to dump bins every hour and by the time they've also had a cup of coffee and a trip to the bathroom it really begins to add up. A full size hopper at each machine emptied would make for fewer trips, but then what do you drain coolant into? A kiddie pool?
    We don't have room to store chips inside, and when it rains here (always) we can't have coolant runoff so briquetters help with reduced volume of chips, and lost coolant. We also have a couple recyclers locally who quoted us a substantial return for briquettes vs. loose chips so that pays for the equipment pretty quick.
  14. #9
    Jun 2012
    Michigan
    5,857
    5534
    3738
    One of our machines makes a ton of alum chips, and coolant gets into the hopper from the conveyor.What we do is we have one of those Little Giant submersible pumps with a garden hose attached to it. We drop it into the empty hopper, fill it up and when we're ready to swap out hoppers, we just plug in the pump and the hose spits it back into the tank.
  15. #10
    Feb 2016
    Washington
    274
    518
    154
    We dump those 1 yard tilt bins on wheels into larger 4 or 5 yard bins. Those have a tapered bottom that drains into a welded up tank below. It works great, but takes up a lot of floor space.
    One thing to be ready for on the PCD is the price. If you aren't buying in bulk the inserts will likely be $80-$120 each. It hurts up front, but they are absolutely worth it.
  16. #11
    Jun 2012
    Michigan
    5,857
    5534
    3738
    One thing you could try that is less expensive are the DLC inserts (Diamond like Carbon) from Kyocera. I'm not sure if other mfg's make something similar but for less than $20 it's worth a shot.
    They have different styles not just the one I linked.
    https://www.mscdirect.com/product/details/97767818
  17. #12
    Apr 2021
    Washington
    30
    24
    5
    J Gilles looks like you are local(ish) what distributor do you get your PCD from?
  18. #13
    Feb 2016
    Washington
    274
    518
    154
    We go through MSC since we have a huge corporate account. I don't think their pricing is great if you are a smaller shop. Not really sure about local vendors. We used to use Stellar, but they didn't live up to their name.
    I'm in Vancouver and if you are close by I'll give you the Kennametal test insert I've got. DPGW3251FST
  19. Likes Silent_Man liked this post
  20. #14
    Nov 2019
    UNITED KINGDOM
    75
    38
    Quote Originally Posted by Mtndew View Post
    Do you or anyone else have any experience with them? Quite curious about those but MSC UK don't have them listed so I'd probably have to buy a pack to try them.
    Korloy make/made DLC coated inserts as well,
    http://www.korloy.com/en/ebook/2018T...s/download.pdf
  21. #15
    Jun 2012
    Michigan
    5,857
    5534
    3738
    Quote Originally Posted by Rob L View Post
    I do not. But for $20 it's definitely worth a shot.
  22. #16
    Nov 2019
    CANADA
    Ontario
    540
    829
    127
    there is the problem, tip radius is 0.016" you need a feed larger then that to control chips.
    that is definitely the wrong geometry insert. looks like it is more designed for cast iron and not a sharp cutting edge for aluminum, it is trying to shear it and not cut it. plus the feed looks really slow to me.
    it is also only a medium chip breaker, need a finishing insert for a finishing chip breaker. ML is a negative insert, you would need better geometry like a MT chip breaker.
  23. Likes GiroDyno liked this post
  24. #17
    Apr 2021
    Washington
    30
    24
    5
    Spoke with a couple reps and have some DLC samples coming.
    It did occur to us that we weren't engaging the chipbreaker, or even using the proper insert. The other half of our applications are cast iron so these inserts may have just been adopted from that. We are going to try a different flavor of insert that should be able to break a chip under a much lighter DOC.
    We don't really want to run faster because the jaws we use are heavy enough that increased RPM might reduce the clamp pressure too much.
    Thanks for the suggestions, keep 'em coming!
  25. Likes Mtndew, mountie, BT Fabrication liked this post
