AMF Marker/Writer
Likes Likes:  0
Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Mar 2013
    Oregon
    38
    16
    Default AMF Marker/Writer
    Does anyone here have any experience using one of these? http://platinumtooling.com/wp-conten...ning_tools.pdf
    I have a job with a lot of engraving and would like to speed things up. Wondering if these are as good as they claim?
    Mar 2013
    Oregon
    38
    16
    If the link above won't open with Adobe, try another pdf reader. I don't know why, but Adobe wouldn't work for me, so I used Drive pdf.
    Feb 2014
    Sunny South West Florida, USA
    3,111
    11167
    3514
    Those are pretty freaking nifty....
    Mar 2013
    Oregon
    38
    16
    Have you used one, or something similar?
    Feb 2014
    3,111
    11167
    3514
    Quote Originally Posted by Darin101 View Post
    Nope, never seen anything like it until your post.
    Feb 2007
    Sweden
    167
    8
    We use a cheaper copy, and it works ridiculously well.
    Some trial and error with different point radius, and spring pressure. When you can go as fast as the machine will go without rounding the corners to much.
    One particular job:
    We had to engrave a logo, about the size of a coin on, a lasercut part. To get the engraving consistant we had to probe each part in Z.
    With the new tool the engraving was faster than the probing cycle alone.
    Dec 2015
    Connecticut
    1,097
    26
    361
    That’s a pretty cool process, the small one seems to be around $1000 USD (971 euro)
    Too rich for me , but I’m going to play around with the process and a shop made version
    Thanks for posting that.
    Dec 2015
    Connecticut
    1,097
    26
    361
    An alternative
    Engrave with a CNC Machine Using A Spring Loaded Engraving Tool
    Mar 2013
    Oregon
    38
    16
    Ripperj, yes it is very expensive $870 for the tool and $660 for the needle. But if it can significantly reduce our cycle time, 50 minutes right now, with almost 30 of those minutes on engraving alone, it should be worth it in the long run.
    Mar 2013
    Oregon
    38
    16
    Ripperj, that is an interesting alternative, thanks for sharing it. My concern with it would be bit life, as it appears to be a cutting bit, whereas the one I posted doesn't cut, it compresses. They say the needles last a very long time, I think I read something like 30000 kilometers of marking, but we'll see. They said they'd take it back if we're not happy with it, so I figured we'll give it a try.
  11. #11
    Mar 2013
    Oregon
    38
    16
    Dallack, what type of material have you used it on and what do you feed at? We need it for a logo on lazer cut 304 stainless.
  12. #12
    Dec 2015
    Connecticut
    1,097
    26
    361
    Sounds like you could recoup your investment quickly. If you get one , I’d love to see pictures of the resulting font.
  13. #13
    Mar 2013
    Oregon
    38
    16
    I've placed the order and it should be in by about mid week. If I can get it to work, I'll definitely take some pictures. Fingers crossed.
  14. #14
    Feb 2007
    Sweden
    167
    8
    Mostly mild steel and aluminium so far.
    Some plastic, but the spring is too hard, so flatness gets critical
    Feedrate as fast as our HAASes will go, about 10 000mm/min
    I don't think we have tried stainless yet, but with coolant it should work ok. A smaller tip radius gives a deeper, sharper engraving with the same spring tension, but maybe a larger radius will slide easier and last longer in stainless?
  15. #15
    Mar 2013
    Oregon
    38
    16
    Quote Originally Posted by dallack View Post
    Wow, that's faster than I had expected. What would you recommend for a starting point for feed? Also, are you running the spindle and if so, what rpm? I will definitely use coolant.
    I ordered a needle with .3mm radius. It was the only size in stock and I don't have 2 weeks to wait for the .5mm.
  16. #16
    May 2002
    South Central PA
    13,731
    2340
    3605
    Real interesting but I don't quite understand how it works. Do you drag it or does it make impact marks?
    We use a Telesys pinstamper to mark parts but doing it right on the machine would be better, and the pictured results are better than our old pinstamper..
  17. #17
    Feb 2007
    Sweden
    167
    8
    Depending on font size I don't think the machine ever reaches 10 000, so maybe start with 5 000 and see what kind of cycle time that gives.
    We have tried both stopped spindle, and slowly turning about 50 rpm. Some controllers need the spindle to be turning to start the feed rate.
    Haven't noticed any difference in turning or stopped spindle
    Propably best to start with light spring tension 0,3 radius will give a nice clean line
  18. #18
    Dec 2015
    Connecticut
    1,097
    26
    361
    What kind of load do you think it puts on the spindle compared to milling?
  19. #19
    Mar 2013
    Oregon
    38
    16
    Quote Originally Posted by Mud View Post
    You drag it. You don't even need the spindle running, unless the machine requires it.
  20. #20
    Mar 2013
    Oregon
    38
    16
    Ok, that's about what I was thinking. I'll be running it on a mori seiki and I don't believe it requires spindle rotation to feed.
    I ordered the slimline model, so I don't know if it has adjustable spring tension. I think you just adjust depth in Z axis.
