Anchoring Barfeed w/o holes in the crete.................
Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Apr 2007
    Pillager, MN
    6,507
    1949
    6390
    Default Anchoring Barfeed w/o holes in the crete.................
    Is there a way to anchor a bar feed without drilling holes in the concrete?(infloor heat) I remember a thread where a machine was "glued" in place? And if I have to drill, what kinda anchors are preferred? Any style that I can minimized drill depth?
    Mar 2019
    Massachusetts
    558
    254
    258
    Quote Originally Posted by david n View Post
    Not sure what kind of barfeed you have. On my 1.250" - 1.500" machines I took a regular feed tube stand and put it inside of a barrel. I then put the lid on the barrel and cut a hole in the middle for the stand to stick out of.
    2 bags of quick crete mixed and dumped inside later and it is a heavy ass deadman. Barely moves, could add much more concrete if needed.
    I have had machines dance a little bit from indexing fast, repetitively for weeks. The machines are all 2400-3200 lbs.
    I am sure there is some type of epoxy/glue that would work great. I have a friend in the industry and he told me the stuff used in snowboards nowadays is leaps and bounds better than 10 years ago. Much lighter and cures harder. Probably more environmentally friendly too. He said they develop new stuff all the time.
    Jan 2007
    Annapolis, Maryland
    667
    923
    363
    Interesting - I never thought of that issue with in-floor heat. How close to the surface does the PEX run? If I ever have that luxury I'll know to either run it 3-4 inches down or measure and mark the runs. How thick is your floor?
    May 2007
    Yadkinville, NC
    234
    Old timer trick is a square of tar paper under each foot. Equipment stays stuck in place without drilling yet can be moved again if needed.
  5. Likes DanASM, Garwood liked this post
    Jan 2019
    Missouri
    507
    145
    129
    epoxy-in anchors. The jigglin of the bar feed seems to loosen the red head expanding type anchors.
    Aug 2012
    California, Central Coast
    5,548
    2442
    2329
    You can also look at the pex pattern with an IR camera. It might help if you turn off the floor for a day or two to cool it all down so the heat shows up better on the IR.
    Another way to see where the pipes are is to again cool it a little bit and pour alcohol on it, it will dry first where the heat pipes are. Heat needs to ON for either of these to work, so a cool floor should ask for heat as soon as you turn it back on.
  8. Likes Murf, BT Fabrication liked this post
  9. #7
    Apr 2007
    Pillager, MN
    6,507
    1949
    6390
    Quote Originally Posted by Antarctica View Post
    My crete is thin in a few areas due to the morons that poured my floor......................................Last thing I want to do is drill into a line. I can use a temp gun to find a line, but doesn't do me much good if the lathe is placed and the bar feed location is fixed.................
    Short servo barfeed btw......................
  10. #8
    Virginia
    23,283
    7561
    13203
    Goal is the barfeed is "registered" to the lathe's spindle anyway.. , not to the floor.
    How about you do the tarpaper trick, then fab a pair of rails from bar-feed to the lathe.. or to the lathe's anchors - or it's anchor POINTS if it is not anchored, either?
    Wouldn't have to carry any mass. Just stand up to - or correct-for - vibration & such as sources of "attempted displacement".
    If it is SERIOUS enough a problem? Steel plate under the lathe that reaches out far enough to pick-up the feeder..drill and tap ..or tack-weld anchors ATOP it.
    Floor and heat system piping doesn't get involved as anything more complicated than a flat top-surface.
    2CW
  11. #9
    Sep 2010
    Oklahoma City, OK
    5,877
    1184
    2619
    What about grout?
    Programmed via Mazatrol
  12. #10
    Virginia
    23,283
    7561
    13203
    Quote Originally Posted by Cole2534 View Post
    What about grout?
    Grout may of may not even be "adhesive". PRIMARY role is even filling of a gap.
    The epoxied plate - one with a close match to the thermal coefficient of expansion of the 'crete (Iron and its alloys, usually..) is about as good as it gets for surface-mount grip.
  13. #11
    Nov 2007
    The South
    190
    21
    Devcon 10610 aluminum putty is holding 2-3 of our bar feeders right now. Clean 'crete and feet well and apply the epoxy. To remove just heat the foot up and give it a rap with a hammer. Epoxy can be easily sanded flush to the concrete after removal.
  14. Likes Antarctica liked this post
  15. #12
    Oct 2009
    Oregon
    6,801
    7286
    4115
    My Kitamura 5X was epoxied to the floor to keep it from walking around at 100% when I bought it. It popped loose without much fuss with a toe jack.
  16. #13
    Feb 2016
    Washington
    298
    528
    169
    I would use one of the Simpson set epoxies under the feet. You could rough up the floor underneath to get better adhesion, but it might rip out the concrete if you ever have to move it. You will also have to figure out leveling pretty quickly after applying it.
    We use the Set 3G to dowel in all thread to existing concrete before pouring something adjacent. It is really impressive stuff.
  17. #14
    Apr 2007
    Pillager, MN
    6,507
    1949
    6390
    PM member Tony36(spelling?) maybe?.............mentioned machines glued/epoxied to the floor. When moved they actually pulled concrete off the surface of the floor.............maybe heat would have prevented that, but there must be something out there.............Devcon 10610 was mentioned above............I'll look into it.
  18. #15
    Sep 2006
    Abingdon, VA
    3,883
    5090
    3954
    There are industrial epoxies made just for anchoring machine mounting plates to concrete.
    The company I worked for in the 90's used it, and it worked well. Like said, if the plates ever needed to be moved, a bit of heat and a blow or two from the side with a sledgehammer breaks it loose.
    Not sure where to buy it...Google may be of some luck?
    ToolCat
  19. #16
    Sep 2010
    Oklahoma City, OK
    5,877
    1184
    2619
    Quote Originally Posted by cnctoolcat View Post
    ToolCat
    Loctite has, in my experience, excellent user tech support. I bet they could steer you the right direction.
  20. #17
    Dec 2008
    Vt USA
    9,946
    1828
    3741
    The PL series of construction adhesives available at any building supply would be the ticket.
    They are POWERFULLY strong, and stick to just about everything.
    Released with sufficient heat.
  21. #18
    Oct 2005
    NORWAY
    985
    518
    206
    I had my mazak Quick turn glued to the concrete. Made 4 steel plates about 4x6" and 1" thick with threaded holes and countersunk a little for the machine feet. Ground the epoxy off the concrete. Rough leveled the machine without the plates. Put the plates with epoxy glue underneath under the feet and let it cure. Leveled machine and screwed down to the plates. The plates took some concrete with them after I removed them (after machine was moved).
  22. #19
    Jul 2015
    Wisconsin
    353
    24
    130
    If you got heat in your ‘crete. Use ‘poxy.
  23. #20
    Jun 2011
    New Jersey
    1,904
    1090
    859
    I always had my LNS' drilled and anchored in. Ugly things can happen if a bent bar begins moving a bar feed.
  24. Likes mr.greenman liked this post
