Anilam 3000 Bolt Hole Pattern Question
Likes Likes:  0
Results 1 to 7 of 7
    Mar 2019
    Default Anilam 3000 Bolt Hole Pattern Question
    Our shop has a Bridgeport with an Anilam 3000M unit. There is no problem using the Bolt Hole canned cycle to drill holes. However, I want to then have the machine repeat the hole pattern, stopping at each hole so I may hand tap that hole before continuing onto the next hole. To raise and lower the quill during tapping I must be in manual mode, but to run the Bolt Hole cycle requires it be in MDI mode. How do I get the machine to stop at each hole position so I may tap the hole. (This machine does not have automatic spindle speed or direction control, so I can't use the canned Tapping cycle). Thanks.
    Jun 2006
    Thunder Bay Canada
    1,792
    550
    297
    Does the control have a single block switch? You might be able to go from hole to hole using that function.
    Dec 2015
    Connecticut
    559
    22
    147
    3 axis and the quill is Z I assume? Is there anyway you can run it just in 2-axis mode? I have 3000m on my Acer knee mill, but it's 2 axis, I used TTS quick change for drilling and tapping, it's amazingly quick (for a manual mill)
    Center drill , drill, power tap, hit the cycle start for the next hole.
    Sent from my iPad using Tapatalk Pro
    Mar 2019
    The control does not have a single block switch.
    The quill is Z, but it cannot be run in 2-axis mode. Also a TTS quick change won't work if the machine won't stop long enough to change the tools. As stated earlier, we need to be able to hand tap after drilling the bolt hole pattern. That requires stopping at each hole and allowing Z axis control.
    Nov 2013
    UNITED KINGDOM
    10
    Hi
    Sorry I can't help your problem, but you may be able to help me. I have purchased a 5oooVS Mill40.1-12.jpg But I didn't get any disks with it. Could I purchase a copy of your Anilam disks for the 3000M controller?
    Mar 2019
    Hi LotusRallyman,
    Unfortunately we don't have the disks anymore. Good luck.
    Researcher
    Nov 2013
    UNITED KINGDOM
    10
    Quote Originally Posted by Researcher View Post
    Hi LotusRallyman,
    Researcher
    Thanks for the quick reply, thought it worth asking.
