Anilam Crusader "M" power supply dead
Results 1 to 12 of 12
    Aug 2005
    CT
    8,017
    381
    2021
    Default Anilam Crusader "M" power supply dead
    Guys
    Does anyone know where I might be able to get my hands on a refurbished power supply for an Anilam Crusader?
    Mine just pooped out, and ... well I'd like it back.
    Ultimately, I am not against putting in ANY other power supply and I'll just wire it up, but the problem is that I need:
    +5V, +12V, -12V, +24V and -24V.
    I am either Google challenged, or these just don't exist in the wild.
    Thank You
    Mar 2016
    61
    28
    What failed in it?
    Capacitors would be an easy fix.
    Aug 2005
    CT
    8,017
    381
    2021
    Nope, not the caps. ( at least not from what I see or smell )
    I've had one blow up on me some years ago, and it was one of the large caps.
    Doesn't look like it this time, though I have not yet pulled the PS out to look.
    The voltage outputs are all garbage. +5V is .73 with the digital meter "pulsing"
    The +12 and -12 is like + and - 2.3-ish, also pulsing.
    Not reversing, so it doesn't look like AC would, but pulsing faster than the readout would update, so the bar graph pulses up and down instead.
    Jun 2006
    951
    897
    117
    Quote Originally Posted by SeymourDumore View Post
    Guys
    Thank You
    What amperage do you need for each of those voltages?
    There’s lots of power supplies floating around that could possibly handle all of those.
    Dec 2015
    Connecticut
    1,205
    29
    406
    Might try Don Schoof at Measurement Technology in MI. I spoke with him in the last week or two. He has power supplies for the newer Anilam controls, maybe he can help
  6. Likes HWElecRepair liked this post
    Dec 2015
    Connecticut
    1,205
    29
    406
    Measurement Technologies and Supply - About Us
    May 2006
    Rhode Island
    89
    17
    8
    Keith, is your email working at this site? I sent you an email message.
  9. #8
    Sep 2002
    People's Republic
    4,831
    505
    2937
    the +- 5 and +- 12 should be routine
    I imagine a +- 24 is available, probably needs some current if the 24 is handling PLC duties
  10. #9
    Sep 2002
    People's Republic
    4,831
    505
    2937
  11. #10
    Jun 2006
    951
    897
    117
    I have a couple of modular power supplies at home that have most (all?) of those.
    I forget which brand it is, but it has a frame that you plug in different modules.
    I’ll take a picture when I get home from my trip.
  12. #11
    Aug 2005
    CT
    8,017
    381
    2021
    I honestly do not know what are the current requirements for each output, nor what they are used for.
    Yes, it is the -24V that's the kicker.
    On that thought however ... could someone answer this dumbass question:
    I can get a PS to get me the +5V and the +/- 12V.
    I can also get a PS for the +/-24V
    So, What-If I get both of them, tie the grounds together and use the outputs as appropriate?
    I mean most of my other machines have multiple power supplies with different voltages and current , and they must be referenced to a common ground no?
  13. #12
    Sep 2002
    People's Republic
    4,831
    505
    2937
    there is nothing wrong with your approach
    don't confuse ground with common, they can be different or the same, just make sure
