M. Moore
Titanium
- Jun 8, 2007
- Vancouver Island, B.C. Canada
Just for the record and because there will be doubters out there.....
Anilam 3000 on a 5hp Topwell mill.
Ran a simple program to cut a gear, 25 teeth and only had a single point tool for the job.
Setup dividing head and let program cut each tooth space with 8 cuts increasing Y depth each pass.
Program ends, index to next tooth space manually and start program again.
This is slow cutting, 250 rpm, 2"/min feed rate so I was doing other things while program ran.
Cut 23 tooth spaces with perfect results, then disaster, the Y axis decided on its own to move to .9 instead of .475, not sure how far it would have gone in Y axis as that was where the machine shut down- too much lag or some such error message on the screen.
Bent the boring bar and pushed the work out of the chuck, damaged the gear and pushed the tailstock out of position.
I was not a happy camper. I did not know that this kind of thing could even happen. I get that you can make a program mistake and have a crash, didn't know the machine can decide to have a bad day and crash.
How do I trust it ever again?
Photo shows setup and results at about #15 tooth space.
