Volitan
Hot Rolled
- Sep 16, 2006
- Long Island, New York
We have an LNS Alpha ST320 that we really don't know how to use.
We can get it to load a bar, but then it just tries to feed it right through the end of the machine.
Playing with the "Top Cut" number helped a little. Is that the number from where the pusher first grabs the stock to your first cut?
Or is it an incremental number from the "Length Measuring Device" to the first cut?
I suspect its the latter because that would make more sense, but that device (a pneumatic door that the stock pushes down thereby tripping it's prox sensor) never goes up into position. How does that thing work? Is it called from a macro by the machine?
There were some issues with this feeder when it first arrived, we had to replace the main circuit board to get it to work. So we don't really know which problems are us and which might be the feeder itself.
