Any other good options besides Haas CM1 for micro machining??
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 63
    Mar 2011
    anaheim, ca
    443
    45
    97
    Default Any other good options besides Haas CM1 for micro machining??
    Any other options out there you guys know of or have used?
    The specs on the Haas are literally perfect for me.
    20 tools
    30K RPM
    12" x 10" x 12"
    750ipm
    5hp
    Most importantly it's only 60" x 48" so I will be able to fit 3 of them in the shop down the road with a little wiggling and some grease. I need multiple spindles more than I need bigger travels, faster rapids, and tapping at a million rpm. I can fit 8 hours of run time in a 12 x 10" space and have a seemingly unending demand for these production parts. I've been running these on my TM2P which is NOT suited for this by any means, the 'roughing' tool is 0.02" finishing is 0.005" so my 6K rpm spindle is murder on my output.
    Nice thing on the CM1 is it has all the needed features at $60K. Literally the ONLY thing I need to add is memory. Funny... my $37K TM2P cost me $60K after adding all the features I needed LOL.
    Datron would be nice... but $ to output makes zero sense at those prices. I could buy 3 CM1s and beat the crap out of one Datron output for less money.
    I just can't find any other options except D/T centers which really aren't designed for this. Before I go to my HFO this week I wanted to ask if I am missing some other options out there in the same price range or if ANYONE has run one of these. I have found NOTHING on the net except a terribly programmed and finished part video from IMTS.
    The next gen control issues has me a little put off and there are NONE of these used. I have seen some OMs around but nothing that screamed 'good deal' vs just buying new.
    May 2015
    Tennessee
    135
    56
    61
    You won't find used CM's, they came out very recently. That also means no pre-next gen control. What Haas had before they brought out this was called the Office Mill, OM-1. If I recall, it was basically the same thing. You might look for some of those used. Seems like the OM's had a 50K spindle. May have been an option.
    Edit: I do apologize, somehow I missed your last paragraph there! You've already looked at OM's. Oh well. Carry on!
    I will add, I don't know anything about Brother machines, but they seem popular for high-speed stuff.
    Oct 2006
    New Hampshire
    177
    71
    42
    Check out Datron
    DATRON High Speed CNC Milling Machines, Engraving Machines
    Oops saw you mentioned them
    Mar 2011
    anaheim, ca
    443
    45
    97
    Quote Originally Posted by Job Shopper TN View Post
    Too popular... trying to find one from this decade used for less than the new CM1 is has been interesting to say the least. If I was 'milling' and 'tapping' they would be my FIRST choice. I really want to play with one, own one and keep it busy, but it would be bored running these parts and a waste of money I think. No way I am going to get a 0.005" tool up to 500ipm feedrate and no tapping to utilize their abilities (and price).
    Jul 2006
    Hillsboro, New Hampshire
    4,747
    1067
    3264
    If you're buying three of the Haas's get some paperwork in place that guarantees uptime and spec-meeting. Ideally run some of your parts on a demo machine before commitment. Ensure they will replace a machine that fails more that "X" times in a year.
    Don't let them sell you crap. Watch your back. Verify, do not trust.
    I used to like Haas, I have two of their machines. But I won't be buying any more after what I've seen of them dropping the ball over the last five (or more) years.
  6. Likes Zahnrad Kopf, pressbrake1, Mtndew liked this post
    Dec 2007
    Austin, Texas
    79
    7
    Another machine that you might want to look at is the Makino N2, but like the Datron you would be trading quality and reliability for quantity. Here is a link to the Makino:
    Horizontal Machining | N2 4-Axis HMC
  8. Likes cnctoolcat liked this post
  9. #7
    Mar 2011
    anaheim, ca
    443
    45
    97
    Unfortunately the three will likely be one at a time and only if the first one doesn't crap out. That is WHY I posted this thread. I would rather not give them money, but I also can't afford to spend 2x more (yet).
  10. #8
    Mar 2011
    anaheim, ca
    443
    45
    97
    Quote Originally Posted by VFP View Post
    Quote request sent. I'm a little scared to see the price THANK YOU! That is NOT one I had seen!!
  11. #9
    Feb 2005
    Akron, OH
    1,626
    231
    1183
    Why do you feel the 30 taper machines wouldn't be up to snuff? A fairly vanilla Brother s500X1 with a 27k spindle should be 80ish, definitely cheaper than 3x a haas if you only expect one to not be broken down at any given point.
  12. Likes 2outof3 liked this post
  13. #10
    Jul 2006
    Wisconsin
    1,270
    222
    887
    How about a little Brother speedio S300 with 27k spindle?
    Theres always a 5 axis DMG HSC 20 with 1,574 ipm on linear drives and optional 60k spindle. Probably pricey but also 3x (or more) the machine that haas is.
    Milling Aluminum on DMG/Sauer HSC 2 linear - YouTube
  14. #11
    Mar 2011
    anaheim, ca
    443
    45
    97
    Quote Originally Posted by JP Machining View Post
    You have one? I'm interested
    I may follow up with them. Talked to them before but was WAY out of my price range.
  15. #12
    Dec 2012
    South Carolina, United States
    111
    20
    32
    Not as enclosed as the Haas, but take a look at
    5 Axis CNC Milling Machine, CNC Machine - MDA Precision
    Similar price gets you 5 axes. And 60k rpm.
    I had a client who needed micromachining, they bought one, I taught them the basics of how to use it, they like it, and never ask me to do any of the hair pulling stuff anymore
  16. Likes Red James liked this post
  17. #13
    Mar 2011
    anaheim, ca
    443
    45
    97
    Quote Originally Posted by Comatose View Post
    I didn't say a 30 Taper wasn't up to the snuff. It's over snuff. Too much snuff. More money (for things I don't need) and bigger (takes up space I DO NEED) for more machines. From what I recall Brother wanted $100K for the machines we talked about. That's a LOT of extra money for useless to me features. I'm not milling. No end mills. No drills. No taps. Brother is better than my TM2P for sure but kind of like renting a Uhaul to carry a trash can.
  18. #14
    Oct 2014
    Maine
    628
    24
    295
    Which Datron were you looking at? the Neo? They look like neat machines but I've never seen any pricing numbers for them; what price did they give you?
  19. #15
    Jan 2010
    Gilroy CA
    4,230
    3033
    2243
    Quote Originally Posted by carl laniak View Post
    These guys are a few blocks from me. Ive heard they are pretty good but havent used one myself.
  20. #16
    Mar 2011
    anaheim, ca
    443
    45
    97
    Quote Originally Posted by DanielG View Post
    They quoted me well over $100K for a USED M8... don't think that neo existed a few months back when I talked to them. Interesting little machine, but dumb as f&%* I have to join their mailing list to see the brochure. Don't matter, I am sure it's far enough north of $100K it doesn't even remember passing it
  21. #17
    Mar 2011
    anaheim, ca
    443
    45
    97
    Quote Originally Posted by dstryr View Post
    That is a snazzy looking set up. Basically a High End Novakon/Tormach machine. Every component looks well sourced/made. I do need more than 8 tools though and my "facing tool" is 1/2" EM. Wouldn't mind the open frame that much... but don't think that is a production machine.
  22. #18
    Oct 2015
    Oregon
    374
    212
    317
    Quote Originally Posted by PriddyShiddy View Post
    No drills, mills or taps? What the hell DO YOU USE?
  23. Likes bryan_machine, npolanosky, adama, Mike1974 liked this post
  24. #19
    Mar 2011
    anaheim, ca
    443
    45
    97
    Quote Originally Posted by Houndogforever View Post
    Haha... I had that coming. 60* engravers for 90% of the time. I "face" with a 1/2" mill and do a cut off with a 1/2" diameter woodruff. It's NOT engraving. It's 3D milling with 0.005" engravers for practical purposes. Rough with up to 0.05" engraver and a quick 1/2" engraver knocks an edge
    (hence the title Micro Machining)
    Wrong words courtesy of Tapatalk and Voice To Text. You bar well come.
  25. #20
    Oct 2014
    Maine
    628
    24
    295
    Why a small engraver instead of a micro endmill (square or ball end)?
