Anybody using MT Connect? Even better on a Brother.
Results 1 to 11 of 11
    Sep 2014
    1,493
    922
    1056
    Default Anybody using MT Connect? Even better on a Brother.
    I have a new customer who is wanting to use MT Connect to monitor their machine. Is anyone doing this and how is it working. Thank you for the feedback.
    Jan 2007
    New Jersey
    786
    314
    294
    We had a machine at the show that had it on an LNS bar feeder for pete's sake. And yes it worked. The machine was monitored and it was also used to control the chip conveyor, mist buster and it also called up programs into the Fanuc control based on the program called up in the bar feeder. This might be an extreme use but it shows some of the possibilities. We were also using it to monitor all of the machines we had at IMTS.
    Paul
  3. Likes 2outof3 liked this post
    Sep 2014
    1,493
    922
    1056
    Quote Originally Posted by LockNut View Post
    Paul
    Paul,
    Did you work with MT Connect directly or with some other third party? Thanks for your help.
    Andy
    Jan 2007
    New Jersey
    786
    314
    294
    There is no such thing as MT Connect as it's own entity. MT Connect is a protocol, open source idea base. Many vendors are doing this now and finding a compitent one is the problem. We use Tech Solve in our showroom for machine monitoring. LNS has their own engineers who put together the show demo for us and it was tied into our monitoring setup that monitored all of the machines at the show.
    Personally, I would not want MT Connect as a per machine scenario running the whole shop because if it goes down, the whole plant goes down. MT Connect has to be implemented from the top down to realize it's usefulness. While an individual machine or cell could do what I described in my first post, it should only be a rung on the ladder, not the ladder itself.
    Paul
    Nov 2011
    Missouri, USA
    2,782
    1354
    2710
    We're currently implementing Memex's Merlin software which communicates via MT Connect with our Okuma machines. We also monitor some other machines but I believe they required alternative hardware. Our Okuma machines are the only ones that I /know/ have MTConnect capabilities.
    Right now all I can do as an end-user is monitor current machine status. I can see whether it's in single-block mode, in-cycle, alarm, idle, etc, and the duration it's been in it's current state.
    Plans are continuing towards much more expansive monitoring and communication (both ways) between operators and managers. There's some things we're playing with to integrate into the OSP controllers to add additional tools for machinists.
    ETA: Fixed my swap in names.
  7. Likes 2outof3, LockNut liked this post
  8. #6
    Dec 2007
    Southeastern US
    6,268
    761
    2645
    We are also using Merlin, but for the Brother they need an add-on card to get signals out because it isn't supported by the control as far as I know. (It could be, if Brother would add the protocol to the control - and if they do, it needs to be on a different port than the TCP programming or the interface ports - I'm using both right now and Merlin would need to be a 3rd connection to the machine.)
  9. Likes 2outof3, LockNut liked this post
  10. #7
    Aug 2017
    Ohio
    Hi Andy, I worked with LNS on these solutions. It's been several months since you posted this, but please reach out to me if bi-directional communication is something you'd like to talk about setting up. I've set up working prototypes with LNS for Doosan, Okuma and Mazak lathes. It has been freelance/side-work for me, but I'm looking to branch out with more customers. Hit me up if you want to chat.
    Joe
  11. #8
    Aug 2017
    IRELAND
    Have connected a number of Mazaks that are using MT connect protocol to connect to Cimco MDC-Max for monitoring.
    Hard to see all OEM's implementing MT connect on there machines, Fanuc already has Focas, Heidenhain has option 18, If you use a NETLink pro you can monitor Siemens 840D
  12. #9
    Oct 2014
    Virginia
    99
    79
    38
    You can get third party, off-the-shelf MTConnect support for Brother from CNC Data, Ltd. (UK). MT Connect Brother Adapter. I don't know how long that's been available or the extent to which UK support for a California install would make any sense.
    I have heard from multiple sources that many US shop floor monitoring companies can support Brother, but I can't find any public references or advertising to support these claims.
  13. #10
    Sep 2014
    1,493
    922
    1056
    Quote Originally Posted by rkwadd View Post
    I talked to the guys at CNC Data and they have a good solution for MT Connect for the Brother control. Also, Factory Wiz showed us a great interface at our Annual Meeting last month.
    FactoryWiz Monitoring - Introduction and Features
  14. #11
    Sep 2013
    Minnesota
    167
    24
    29
    You might look at Scytec DataXchange. It can do a lot and seems like it has good support but personally I don't care for their subscription based fee.
