Mud
- May 20, 2002
- South Central PA
We want to try using a tapping head in a Prototrak bed mill with a AGE3 control. The control doesn't know the speed of the spindle so we'll have to estimate it and the feed accordingly and hope it matches. My proposal is to program conservatively on the feed with a boring cycle and adjust the spindle speed or the feed as necessary. We'd be changing tools and spindle speeds during the cycle, so it might be best to verify the spindle speed with an IR tach each time.
We've done it in the past using 2D programs and manually operating the quill. We'd like to power drill the hole operations using 3D, but trying to do that then manually operating the quill for the tapping head causes the control to error out as soon as the quill is moved - that's why we want to try powering the tapping head in and out. The tapping head is a CNC model with equal in and out speeds.
Or is there a way to interrupt a 3D program and manually tap each hole?
Anyone here done this already? Have any tips?
