Anyone else have a HAAS TL1 Next Gen Controller (threading issue) - Page 2
Results 21 to 40 of 58
  1. #21
    Nov 2014
    Florida
    3,612
    1512
    1711
    Quote Originally Posted by LMNTS View Post
    Everybody:
    Yes, we used proper tools for measuring the thread minor OD. We have several people do it. It's off by 0.035" (not deep enough).
    Yes, we are using the proper measurement tools, the proper settings for the tooling, AND the proper G Code for the expected thread.
    We have tried this upside down, backwards, and in 8 different languages. We have had the experts of experts in here.
    It's either a machine problem, software problem, or Haas problem.
    My main goal of this post was to find someone with the same model and generation machine to confirm if what Haas is telling me is true.... that they do this on purpose.
    I still don't understand why you are checking the minor dia on an OD thread?. What does the PD check? Is it also off by .035" ??
    Just a thought, take your threading tool and program a little turn, maybe .25" long so you can accurately check, and let us know if that is the correct diameter. That might at least point to the threading cycle or a tool/offset problem...
  2. Likes doug925 liked this post
  3. #22
    Nov 2014
    Florida
    3,612
    1512
    1711
    https://www.natool.com/wp-content/up...atp101-102.pdf
    https://www.fastenal.com/content/fed...s%20Design.pdf
    I'm sure there is a ton more info, my point is minor diameter is a poor choice for checking threads....
  4. #23
    Nov 2019
    Michigan
    18
    Minor Dia, Major Diameter - it doesn't matter. The machine is not going deep enough by roughly 0.035".
    Simply put, the machine is deciding on it's own to not go to 0.416 like it says it will.
    Turning on this machine is only off by 0.001" or 0.002", which in my mind is great!
  5. #24
    Nov 2019
    Michigan
    18
    It doesn't matter what we measure. It's all off by 0.035" for a 1/2-13 thread. Turning anything on this machine is dead on. It's only threading.
  6. #25
    Sep 2006
    SW Wisconsin
    491
    15
    115
    (THREAD MAJOR DIAMETER = 0.5)
    (THREAD MINOR DIAMETER = 0.416923)
    (THREAD HEIGHT PER SIDE = 0.048077)<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< PER SIDE!!!!!!
    (OPTIMIZED "A" VALUE FOR 60 DEGREE THREADS)
    (SEE SETTINGS 95, 96, 99 AND 289 ON THE CONTROL)
    T505
    G54
    G97 S550 M03
    G00 Z0.01
    G00 X0.52
    M08
    (**WATCH FOR LIVE CENTER INTERFERENCE**)
    (RECOMMENDED Z-AXIS START IS 3 THREADS FROM START POINT)
    G00 X0.52 Z0.01 M24<<<<<<<<<<<<<<<<,should Z be larger???
    G76 X0.4169 Z-3. K0.0481 D0.012 F0.0769 A60<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< DIAMETER!!!!!!!!!!!!!!!
    G00 Z0.01
    M09
    After fixing that get away from the idea of measuring minor diameter, it WILL fake you out! Get a thread mike or at least thread wires if you want to do the best job.
    Ed.
  7. #26
    Dec 2003
    poulsbo, wa, usa
    722
    36
    298
    This might sound nuts but give this a try .
    Set up your threading tool and just run it as a normal turning tool and spin a shaft down to lets say 1.000 dia with just a simple G1 feed move and then verify the dia it cut. without screwing with any of the cutter comp setting then run a G76 with a X dia of .950 and a low feed per rev of like .005 and see what the cut dia is ?
    ** ONLY SET X AND Y offsets for the threading tool ,,, leave all other lines blank for that tool offsets.
    That well tell you if the infeed for the G76 cycle is reading right or not ...
    Also check with Haas if the control might be using a infeed at a angle and not just in X direction. I some place remember reading about a control setting to change how the is done well doing a G76 on Haas
  8. Likes doug925 liked this post
  9. #27
    Nov 2019
    Michigan
    18
    Quote Originally Posted by atex57 View Post
    T505
    G54
    G97 S550 M03
    G00 Z0.01
    G00 X0.52
    M08
    G00 Z0.01
    M09
    Ed.
    Hi Ed, after fixing what? Per Side! Diameter!!
    Not sure what you're talking about.
    Try running the program I posted on your machine and tell me what happens!
  10. #28
    Sep 2014
    Michigan
    31
    8
    How many passes does the machine make to get to its final point? Curious if its stopping early or if its going to the wrong location.
    Going to throw something stupid into the ring: try checking your G76 minimum depth of cut setting (Setting 99). Remember the D is, unless stated otherwise, the INITIAL depth of cut. It reduces it from that point based on the A value to keep constant cross section. D.012 is a pretty small number, so your definitely hitting that setting. I don't know the behavior if the minimum cut is 0. It may just stop. We had our machine set to .003 I think. Could also try adding a P3/P4 to the Gcode line, it'll infeed the D value the constant amount. The conversational wont do that for you though.
  11. #29
    Oct 2012
    Orange county, CA
    99
    6
    21
    i replied to your other thread as well:
    so i just made a 1"-12 thread on the TL1 here at the Haas Factory, and I used VPS to program the thread
    both VPS and the internet say the minor diameter is nominally .909
    I had to budge the X wear offset by -.013 to get the go gauge to fit, which is typical.
    i don't think there's anything wrong with your machine.
  12. Likes Booze Daily liked this post
  13. #30
    Oct 2012
    Orange county, CA
    99
    6
    21
    here's the program i used
    O02323 (THREAD)
    (OD THREAD CYCLE)
    ( SAFETY LINE BELOW )
    G00 G54 G18 G40 G80 G97 G99
    (TOOL = 2 / OFFSET = 2)
    (WORK OFFSET = 54)
    (SPINDLE RPM = 630)
    (THREADS PER INCH = 12.)
    (THREAD MAJOR DIAMETER = 1.)
    (THREAD MINOR DIAMETER = 0.91)
    (THREAD HEIGHT PER SIDE = 0.052083)
    T202
    G54
    G97 S630 M03
    G00 Z0.3
    G00 X1.4
    M08
    G00 X1.4 Z0.3 M24
    G76 X0.91 Z-1. K0.0521 D0.013 F0.0833 A59
    G00 Z0.3
    M09
    G00 G53 X0.
    G00 G53 Z0.
    M05
    ( END OD THREAD CYCLE )
    M01
  14. #31
    Nov 2019
    Michigan
    18
    Thanks for the reply.
    Any chance you can do a 1/2-13? We don't do any 1" and we don't have inserts to try your program and verify.
    On the 1/2-13 it says it would go to 0.416, but it is off around 0.035" every time, regardless of insert, insert age, etc.
    If there is nothing wrong with the machine, I would expect that you would have to do something similar.
  15. #32
    Nov 2019
    Michigan
    18
    Also, can you please tell me where you are setting your X wear offset of -.013"?
  16. #33
    Oct 2012
    Orange county, CA
    99
    6
    21
    if the machine is making good 1" threads, it will also make good 1/2" threads; i made a 1" since that was the gauge i had handy.
    you never said how much X wear offset you were making when dialing in your thread.
    if your go gage won't go, keep subtracting -.003 from the X wear offset until it goes nicely.
    I think that's what you're missing
  17. #34
    Oct 2012
    Orange county, CA
    99
    6
    21
    on the tool offset page, scroll to the right until you can see the wear offset. you can't just type in -.013, you have to sneak up on whatever value incrementally, generally by less than the tolerance of your pitch diameters which should be listed on your gauges.
  18. #35
    Sep 2015
    Ohio
    1,089
    656
    1059
    Are you sure you have your X offset set correctly? If you program it to go to .416 but have to cheat it .035 , it doesn’t sound like it.
    How are you checking the minor?
    Ok, so now you have your thread insert cutting at .416. Now what?
    It’s still not gonna gage. You need to edit the X value until it does.
    Who cares what that number is if you get a good thread.
    Also, you don’t say what kind of threading tool you’re using. If it’s a Top Notch style your X offset between a groove insert and thread insert won’t be the same.
    Also, the major dia for a 1/2-13 isn’t .500 you need to turn it down
    Also, if you edit your target X make sure you adjust your K accordingly or you’ll take a hellacious first cut.
  19. #36
    Sep 2006
    SW Wisconsin
    491
    15
    115
    The point I was looking at was a possible wrong parameter that uses diameter instead of radius on offsets.
    My nephew has a TL1 and said the program you list as correct, check your offsets.
    Get a thread mike or wires so you can get a true reading of size and/or keep cutting deeper until a nut fits.
    Do you know how pitch diameter works?
    Ed.
  20. #37
    Nov 2019
    Michigan
    18
    Quote Originally Posted by coyoinu View Post
    I will try this first thing Monday morning and feedback our results.
  21. #38
    Feb 2013
    Idaho
    668
    139
    717
    Also, when it is running the final pass, look at the X position on the DRO... what does it read?
  22. #39
    Jun 2016
    Minnesota
    235
    73
    105
    How long have you ran cnc lathes? You are freaking out over this not working yet anyone that has run any amount of CNC lathes know you have to fudge things. Whether it was an old Dynapath or a Mori Seiki I have ALWAYS had to fudge. The thing being though, is normally once you figure out by how much on what lathe, you put that in your wear offset, so then you don't have to mess with the programs.
    Also the fact you will not explain how you are taking measurements is a little disturbing. You should be using a thread wire guage set if you to have a optical guage to check minor. Also, your Z was 3in long which could result in deflection easily if you are not using a tailstock(noticed your program warns user , but didn't know if you are)
    Good luck, but this is small peanuts compared to guys running 11 axis lathes. Adjust your wear for that thread tool and get on with making parts.
  23. Likes g-coder05 liked this post
  24. #40
    Mar 2013
    Oregon
    1,763
    725
    2073
    We have spent several hundred hours working on this.
    JFC dude... melodramatic much?
    If you've honestly spent "hundreds" of hours on a minor issue that can be fixed by bumping an offset, how the hell do you stay in business?
