Anyone using rechargeable lithium batteries in Renishaw probes??
Results 1 to 8 of 8
    Apr 2016
    Washington
    156
    155
    88
    Default Anyone using rechargeable lithium batteries in Renishaw probes??
    Hi All-
    I've got Renishaw work and tool probes in my Okuma M560. Both probes eat SAFT 14250 Lithium Thionyl Chloride batteries in large quantities. Need to put in a new set of batteries every 4-6 weeks. Not a huge expense, but they're not cheap either.
    Has anyone tried using rechargeable Li-Ion batteries?
    Looks like 3.7v rechargeable 1/2aa 14250 batteries can be purchased with 300-600 mAh capacity, which is significantly lower than the disposables @ 1200 mAh. But with ~500 cycles life...
    Maybe a waste of time/effort... Just hate disposable batteries...
    Jan 2014
    Washington
    5,430
    978
    3013
    A Li-Ion battery fresh off the charger will be at 4.2V for a bit before settling in to the nominal 3.7V rating. Something to keep in mind if considering trying it. I'd contact Renishaw and bounce the idea off them.
    On the old MP10 series spindle probes, I have seen folks use NiMH 9V rechargables with no trouble.
    Jan 2019
    Arizona
    1,168
    107
    467
    Quote Originally Posted by Mooner View Post
    Hi All-
    you might want to contact Renishaw and see if there is a problem. like your probe is on all the time?
    our tool probe is used 10-30 times a day and the spindle probe sometimes every part. we generally replace batters every 6-8 months or more.
    our machine is a hass
  4. Likes Chris59 liked this post
    Jan 2014
    Temecula, Ca
    3,280
    1398
    4289
    sound like you're buying shit batteries. We buy good fresh ones and they last close to a year. A while back, we had a guy find a great deal on them on ebay. They sell old expired shit. Typically they would last about a month.
    Nov 2014
    Florida
    5,683
    2252
    2827
    Hi All-
    4-6 week replacement cycle sounds like something is wrong as others said. Also, not sure if it really matters or not, but if you look Renishaw only recommends 2 brands of batteries (or used to), Saft and some other brand that escapes me at the moment.... Haas machines here too.
    Jan 2014
    Oregon
    574
    119
    404
    I have been having a really hard time finding good batteries in that 1/2 AA size. For the last couple years, nothing lasts more than a month.
    It's such an issue, that I am considering replacing the OMP40 on my Okuma with an OMP60 like my other machine. The 60 takes AA batteries. Been using it dozens of times a day for almost a year, and it's still on the first set.
    Apr 2016
    Washington
    156
    155
    88
    Thanks all... Now that I think about it, I'm probably exaggerating a bit. I'm changing batteries every 4-6 weeks, but probably only either the tool probe or the work probe. Only rarely do they both need to be replaced at the same time. So I'm probably getting closer to 2-3 months out of a single set of batteries...
    I'm probing 4 fixtures / 24 parts / 10 tools each cycle, so sounds close to what others are getting.
    I guess I'll just stick with the SAFT 1/2AA disposable batteries...
  9. #8
    Aug 2010
    Medina OH
    2,322
    324
    1126
    I just replaced my spindle probe batteries , just shy of 1 year. It doesn’t get used every day, but when it gets used, it gets used a lot.
    I shopped for Saft batteries for awhile, in the past I have learned not to buy batteries from amazon, 90% of the time they are expired or fake.
    I wound up buying them from McMasterCarr. Batteries went from the blinking battery low, to battery dead in less than an 8hr day, so McMaster saved my butt with next day delivery.
