I have a 2008 Haas SL30. I am the original owner. A couple of months ago I had a part come out from not enough clamping force. It wedged between the turret and chuck. I did move the wedge on the machine.
I had HAAS come and do an alignment. It still seems as though something is not quit right. The part I am on now has 2 bores. One is a 2.320" and the other is at 1.258" The finish parts are coming out 2.319 / 1.258
All I can assume is it is off center. I swept in the boring bar and it was off I put it on center better but same problem.
I have a copy of the SL maintenance manual but not sure if it is in the exact order plus it jumps between turret styles. Mine is the BOT style.
TIA
TIA
