Appropriate air supply for CNC Machine? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 21 of 21
  1. #21
    Jun 2006
    761
    668
    96
    Quote Originally Posted by triumph406 View Post
    Get the cheapy HF or HD compressors, I've been using a Husky 2.0hp 30 gallon tank compressor with 2 fadals, a Makino, an air drawbar on a BP, multiple leaky fittings etc for 4 years now. The only issue I had was running low on oil, adding oil fixed that.
    If you don't think that's going to be reliable enough, buy 2 of the HF or HD compressors, plumb the tanks together so you have 60 gallons capacity, and use only one compressor, when that craps out after a few years, plug the other one in.
    I like this idea and I'm basically doing it using a 60 gallon tank from an HD compressor where the motor was gone. I've plumbed it inline.
    One large problem I have with the Harbor Freight and Home Depot compressors is the noise!
    I have a California Air Tools super quiet compressor, but it is far too wimpy.
    I know it's like hunting unicorns to try to find a quiet compressor that can produce a lot of air and has good duty cycle, but I'm tired of eating canned unicorn meat!
  2. Likes triumph406 liked this post
