Arbor - can someone identify the machine it belongs to please?
Peter S
May 6, 2002
Auckland, New Zealand
I bought a drill chuck recently; it was attached to this unidentified arbor.
I wondered if someone could tell me what machine this would suit?
The markings are "Fanuc" "Big" "30-J6".
There is a large ball bearing on the arbor, I presume it is used by a tool changer?
Thanks for any help.
Arbor Fanuc 30-J6 01.jpgArbor Fanuc 30-J6 02.jpgArbor Fanuc 30-J6 03.jpgArbor Fanuc 30-J6 04.jpg
View attachment 258265View attachment 258266View attachment 258267View attachment 258268
Try these folk:
Basic Arbors | BIG KAISER
It would "suit" any spindle and changer with matching taper and same-family of pull-stud.
Pull-stud being removable/changeable as well as replaceable, it could also suit manual machines with ignorant drawbars so long as the drive lug(s) were also compatible or could be made to be.
"Many, many", IOW.
Just noticed the OP is from New Zealand. The machine was probably called something other than what I wrote above. Pratt & Whitney was the US importer/distributor. No idea who was the importer/distributor for NZ (likely Australia too). Maybe angelw or machtool will chime in on this.
Poorly worded question perhaps - I would like to know what machine it was originally made for. The large bearing makes it fairly machine specific I am guessing.
Vancbiker,Thanks for the P&W suggestion.
BTW, this arbor had a nice Japanese drill chuck on it "Yukiwa Heavy Duty Ball Bearing Super Chuck", a new name to me.
Further to vancbiker's posts, I had a look for a P&W Tapemate Model C. It seems they are the same as (or made by) Fanuc Drillmate Series C.
This guy has a few videos of the P&W machine, the bearing looks to be holding the tool in the rotary drum/turret, not a arm-type tool changer. He thinks it is BT 30 tooling. He also says Fanuc got rid of the bearing on later models.
YouTube
Another guy "Hood" (who I think is a PM member) has a Chiron FZ12S with similar tooling (SK30 he says). However this tooling uses a thinner bearing and a brass ring. It seems you can change the Chiron tooling to the wider bearing and it will fit the P&W/Fanuc.
This machine is quite a sight!
YouTube
Any further info welcome!
YouTube
The toolholder you have is definitely not for a Chiron. I had the unfortunate experience to be an FSE for a Chiron distributor for a couple years. Without a doubt the most troublesome toolchanger I ever saw on a "modern" machine tool. Very maintenance intensive. Chip contamination being by far the most common cause of trouble.
Agreed, the Chiron holder is is not the same as mine.
Just mentioned the Chiron because the guy with the P&W above had converted some Chiron holders for his machine. Although I am not 100% sure he had tried them when he posted here (see Reply No. 15 which compares Chiron and Fanuc/P&W holders):
Putting tools in tool holders
LOL! Yah.... welll....
And it seems you got it. PM at work.. etc.
... a nice Japanese drill chuck on it "Yukiwa Heavy Duty Ball Bearing Super Chuck", a new name to me.
New name to me as well - as was also a French high-grade drill chuck maker that surfaced on PM this past week. (Spanish ones I have, already).
Best outcome would be that the nice chuck has a standard arse-end that readily fits <whatever other > toolholder you - or a potential purchaser/trader - actually have a machine for.
.....BTW, this arbor had a nice Japanese drill chuck on it "Yukiwa Heavy Duty Ball Bearing Super Chuck", a new name to me.
Yukiwa is still around. I mainly know of them for their rotary tables which were offered on some Mori Seiki VMCs back in the 90s. IIRC, one or more of the Brother threads here talks about having Yukiwa rotary tables on their machines.
Yes, it was the chuck I wanted. I am a great fan of Jacobs ball bearing drill chucks, so wanted to try this Japanese version. It has a J6 taper.
The arbor was just a curiosity.
One very nice feature of the arbor is the jacking nut for the chuck - what a great idea. Why don't all drill chuck arbors have this. Perhaps it is common on CNC machines. Tapered wedges are not always the answer for example, a small morse taper may not have any shoulder for the wedges to act on.
My very humble 1940-something Walker-Turner drillpress has the same thing - already an old, old idea.
There are also the reverse: Threaded retention rings.
As to why not more common? I doubt either concept "scales" all that well.
A ring with enough beef to break-loose my 5 MT goods would take up a LOT of scarce space right on the machine. The wedge, lever, and "ratcheting" differential drifts for all that OTOH only take up space in the box!
Just to remove drill chucks from their Jacobs taper ....
".. with lower risk of damage to the chuck than 'pickle-forks', wedges, hammers, etc."
Certainly.
Cost-justifiable, OTOH? Generally "no longer the case".
At the present-day cost of decent chucks vs human labour, fully-burdened? For "revenue" shops it may be cheaper to scrap the whole rig - toolholder as well as chuck - for the certainty of performance of a brand-new package and just keep on making parts, fewer/no distractions.
