Assistance with troubleshooting Anilam 1400M servo problem. - Page 2
Likes Likes:  0
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21
    May 2020
    Arkansas
    10
    I can find multimeters but I have no way of knowing if it will measure what I need. Will this work? Test Range: 2/20/200/750 VAC, 200mV/2/20/200/1000 VDC
    I also found a fluke 110 but I cant tell if its what I need.
  2. #22
    May 2020
    New Hampshire
    The Fluke 110 should work fine. Its spec sheet shows that on the 600mV range it has 0.1mV resolution. This is perfect. (This is basically the same meter that ss_user recommended.)
    I can't tell about "Test Range: 2/20/200/750 VAC, 200mV/2/20/200/1000 VDC" but if you can get me the manufacturer and model number I can look into it.
  3. #23
    May 2020
    Arkansas
    10
    Allrighty thanks for the information that my Multimeter was wrong. I found the problem, It was that some dumbass (not me) rearranged the wiring connector on the servo board. Got them put back according to print and no more runaway... Still gotta do some balancing and adjusting gain, buy I'm in a better place than I was.
