I need to buy a tool and I'm hoping for some help on deciding. Ball endmill, .5" Dia, 3" flute length, 6 overall, 3.25" tool stickout, and carbide.
The thing I want advice on is if I should go 3 or 4 flute when I'm cutting 6061 aluminum. Yes I know that 3 flute is the go to, but because of the large tool stickout and flute length. I'm worried about rigidity and chatter while machining. The machining operation is doing a radius at the bottom of a 3" hole.
Thank you.
Thank you.
