ricardo_gt
- Aug 5, 2012
- Portugal
Hi people,
I am having a problem at a Gildemeister fabricated at year 2002 lathe:
After machine and correct the first part at the machine it is suposed to machine 50 parts continuously, without any correction on the offsets and the part staying inside the tolerances, even after part number 50...No way i can get that at OD and ID... all diameters go out of tolerance somewere from 11 to 13 part and continues to go away from nominal values. This happens as this: OD X axis comes down and X values decreses and ID values also comes down, diameter comes tighter and tighter. First i tried to warm up machining at least 50parts, correct offsets after and machine more 50 without touching offsets... did not worked. I changed the tools to new ones, all new, inserts and irons...the same.
It uses mist coolant and it are stainless steel cast parts, just needing finishing, 2.0mm (metric) plus all around.
The part have 60mm outside and 30mm inside, +-0.015 tolerance (metric) and 40mm long.
I am using carbide inserts.
It is the first time i have a machine that can not keep tolerances for long and i do not know were to search what or why.
I accept any advice. Thank you.
Best regards.
Best regards.
