trioautomach
- Aug 23, 2013
- Minnesota, USA
We have been playing around with a simple and easy performance enhancer for our old B&S screwmachines based on easy to aquire components. It has helped immensely to tame these old machines. The following link says it all.
Brown & Sharpe CNC retrofit - YouTube
By replacing the middle gear shaft on the cycle gear train with a servo we can drive the cam train & trip dogs in any direction at speeds from 10 seconds to infinitely slow. It doesn't require any drilling or welding and can be removed as fast as changing gears. The heavy lifting of collet closing, indexing and spindle shifting is still done by backshaft motor. Now if we have trouble with one tool we can slow just that tool down. Or even add a pull out on a drill if it needs one by backing up alittle ( if no conflict with other tools) and getting thread feeds just right is only a matter of keystrokes. We can use programmable dwells and loop programs to count cycles and stop for inspection and beep. Let your imagination go to work.
The system consists of a PC with hobbyist software , a power supply, a little black box and a servo motor. The final arrangement cost less than $1500
