Hello all
Recently purchased used Okuma LB15 with OSP7000L control. Running first job and getting terrible finish on face, weather od or bore. Getting circular lines as if I'm running low rpm and high feed rate. I tried running at different rpms, from 300 to 2000, and feeds from .0005 to .01 and no change. Also changed facing tools and boring bars, different inserts and so on, getting same results.
Things to note:
Spindle is loud and has runout of .0006" so I may have a bad bearing. But X axis turns are repeating within .0001"
Is this likely caused by a bad spindle bearing or could it possibly be something else?
Any suggestions would be very helpful
Things to note:
