Bandit Controller Electrical Schematic needed for Shizouka AN-S CNC Knee Mill
Bravo81bw
Feb 3, 2020
Hello everyone,
I just wanted to know if anyone has the electrical schematic for the Summit/Dana Bandit controller on a Shizouka AN-S CNC knee mill. This machine is from the 1979-1980.
The sticker on the bandit controller has the following information.
Model No.: 21-300-33 ?
Serial No.: 803445
115 VAC, 60 HZ
I’m not sure if these numbers are correct as they are very hard to see
Currently, when I turn on the controller the following lights turn on.
1. Contouring Entry
2. -DN
3. /Shift
4. Reload
Please see attached photo.
At the same time the X and Y-axis motors shake rapidly back and forth.
Any help would be appreciated.
Thank you,
Don
Try a search for Len Albright, Albright's CNC Support Services. He's helped me out with the old Bandit controller. He's very knowledgeable & good to deal with.
J.
no help at all-but surprised how 2 california. shiz posts show up simaltaneously--i'm in sebastopol-where are you and yours?--pat
If no one else can help you get back to me. I had one with all the manuals and the guy I sold it too likely still has the manuals and the entire controller too as he retrofitted it with AB controls.
There's a lot of CNC stuff that doesn't surprise me it still runs and people still use it all the time.
A Bandit Shizuoka does not fall into that category.
That thing holds like 4 lines of code in it's memory. I hope it doesn't have a toolchanger. If it does, realize that toolchanger is what Fadal built it's empire on.
I'm in Oakley/Brentwood area. I got the machine from a machine shop in Concord making aerospace parts.
-Don
It has a tool changer.s-l1600.jpg I replaced all the seals/o-rings in the air valves20200118_202326.jpg20200119_014329.jpg, arm, and pneumatic ram20200119_212143.jpg. It seems to be working fine in local mode. Well, so far.
-Don
Hi Gary,
I have the following manuals for the machine:
2. The tool changer operation manual
3. The Danetics Mill Bandit Programming Manual
I really only need the schematic for the controller. But if he is willing to part with the controller manual, I'll take it. If he asks, I'm willing to pay for a reasonable price.
Don
No help here, but you sure bring back memories. I cut my teeth on that mill bandit control. Got parts from Albright, mentioned above.
I used it hard for 20 years, never had an issue with the control. With a whole 50K of memory, I got good at writing looping gcode to save program space.
I did upgrade the mill to a new refit control in 2002. I would suggest you consider doing the same.
