Bar runout
Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: Bar runout
    May 2021
    CANADA
    Ontario
    8
    Default Bar runout
    Hello everybody,
    I need to make a lot of parts from 4' long bars, O.D. is 1.750" we don't touch it, inside boring to 3.150" depth, eccentric tolerance is .005 ". I use a bar puller and put 3 plastic sealing rings inside the machine tube. There is almost no runout near the collet, but at the end of the bar it is about .01 ", but not always, sometimes runout is OK - .002", I cannot fix this problem. What to do? Can the Spindle Liner help?
    Jun 2015
    Minnesota
    764
    12
    271
    Never mind... I read it wrong. Deleted previous stuff. (Insert head slap)
    Jul 2006
    Hillsboro, New Hampshire
    13,460
    2989
    9076
    Quote Originally Posted by edtcadcam View Post
    Hello everybody,
    Are you starting with centerless ground material?
    May 2017
    Minnesota
    1,879
    2490
    1278
    Solution: runout to the bar.
  5. Likes plastikdreams liked this post
    May 2011
    New Jersey
    2,989
    299
    1648
    You are using barstock that doesn't have the od turned...and you are wondering why there is deviation...are you high?
    Dec 2012
    Se Ma USA
    2,237
    180
    1218
    From information provided. Do something at other end, maybe something different in the middle. First few parts OK? Good, make first few parts and get another bar. Or maybe OK, make more parts. Or day off and go to bar.
    Most times a problem must be very well defined before any solution can be offered. Most times defining the problem accurately will give you the solution as you define the problem.
    If the wind does not get to you, the wife will. Maybe wrong Province. Police tape all over the lobby went we went to breakfast. Seems somebody decided to rob the hotel night clerk. She beat the crap out of him and he ran off.
    Jul 2019
    Florida
    4,265
    4099
    816
    Spindle liner can help the less gap the getter. Less gap is better you maybe can make a thin cap to fill in any gap. Slide it over the end of shaft into sleeve. Tape it in to stay.
    When it turns it can run out more the more gap you have. Bar feeder may be hurting you. OD of material can be bumpy so you can run a file gently over the od even pull it through 7 inches turn it slow and gently file the od safely any raised spots can be seen and filed off gently here and there . This gives your precision collet a better surface to clamp on it is more accurate.
    Best end first to clamp on with the collet. There are ways to check the runout using precision V blocks or down and dirty the gap on the bed of a manual mill. Look the od of the material over any bump will freak you out as you might think your shaft is running out. Two precise V blocks and rotating it by hand with the V blocks clamped or say in clamped two vises. Shaft is spun by hand and use a indicator on I’d and wherever you think it makes you conceive how it actually is. I think it will be good.
    I hope this helps you in some way. I think some precautions will help. What you see as .01 over four feet likely can be lessened with some thinking and attention. Oft times I will clamp turn 120 degrees and check and again check and again check each time for runout to see if how it clamps effects the runout better or worse. Work with something patiently and persistently things will come to mind.
  9. #8
    Jan 2013
    Plainfield, Indiana, USA
    1,846
    1433
    986
    Saw your parts to near finish length ... gives you collet a chance to hold true without orbiting and ruining your collet head. Likely won't loose any more material than you are wasting with a cutoff tool.
  10. Likes Trueturning liked this post
  11. #9
    May 2021
    CANADA
    Ontario
    8
    This is cold rolled 1018.
  12. #10
    Oct 2005
    22,006
    So it's NOT ground material.
  13. #11
    Dec 2009
    CANADA
    Ontario
    53
    23
    72
    It's cold drawn. Many times at the end of cold drawn bars you will find that it is bent from the shearing process.
    You can try by cutting 4-6" off each end first to see if that helps the problem.
    As already stated, I would highly recommend getting centerless ground bars for process reliability.
  14. Likes Trueturning, Fancuku, EnderDRM, Ox liked this post
  15. #12
    May 2011
    New Jersey
    2,989
    299
    1648
    Or get 1.875 or 1.8125 and hit the od real quick.
  16. Likes Chris59 liked this post
  17. #13
    Oct 2005
    22,006
    more discussion going on here:
    Bar runout
    the OP "cross posted it".....
  18. #14
    May 2021
    South Carolina
    What do you call a lot of parts . Best case cut off and face and bore using pie jaws. May take more time but you will get good parts.
    Dennis
  19. #15
    Nov 2013
    Utah
    5,107
    1335
    2908
    Eeesh, Solutions above and below. Because what you're doing isn't ever going to work with CR bar stock.
    A. Pull bar, insert M0, indicate bar close enough, Bore, cut off.
    B. Cut parts to length, Bore inside the closer.
    C. Get TGP.
    D. Bore inside closer, push out, cut off.
    E. Something else.....
    R
  20. #16
    May 2021
    CANADA
    Ontario
    8
    Quote Originally Posted by [email protected] View Post
    Dennis
    This is about 12,000 parts, everything should work from a bar, quickly and without problems.
  21. #17
    May 2021
    CANADA
    Ontario
    8
    Too much time and cost. This is a production of 12,000 parts. Besides, the material was purchased by the customer.
  22. #18
    May 2021
    CANADA
    Ontario
    8
    1018 cold rolled is a pretty precision material with a tolerance of .002 "
  23. #19
    May 2011
    New Jersey
    2,989
    299
    1648
    Regular off the shelf cold rolled bar is not straight, nor concentric. If you believe that than you are more the fool than originally led on. Centerless ground bar will be straight and concentric.
    If only a few are out of spec, throw em out and continue on.
  24. Likes Fancuku, Trueturning liked this post
  25. #20
    Nov 2013
    Utah
    5,107
    1335
    2908
    I gave you solutions that require very little time, just a change in operations. Cold roll isn't round, it isn't straight. Also you don't know the vendor, if it's customer supplied. Could be Chicom shit. 12,000 pieces isn't that much, your guys will get very fast at using a deadblow.
    R
  26. Likes Trueturning liked this post
