Bar runout - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
Thread: Bar runout
  1. #21
    Dec 2018
    220
    557
    57
    Quote Originally Posted by edtcadcam View Post
    1018 cold rolled is a pretty precision material with a tolerance of .002 "
    No it is not.
  2. Likes Trueturning liked this post
  3. #22
    Jun 2012
    Michigan
    13,799
    4686
    4971
    Can you put the out end in a steady?
  4. #23
    Nov 2012
    Wisconsin
    115
    291
    14
    Quote Originally Posted by enginuity View Post
    It's cold drawn. Many times at the end of cold drawn bars you will find that it is bent from the shearing process.
    You can try by cutting 4-6" off each end first to see if that helps the problem.
    As already stated, I would highly recommend getting centerless ground bars for process reliability.
    The 6" off the end part.
  5. #24
    Jun 2021
    New York
    Put an exactness test bar [2] into the axle. Put the tip of the marker straightforwardly underneath the check line to gauge runout. The TIR at the check line should not surpass 0.0005" (0.013 mm). Put the tip of the marker against the test bar roughly 6.0"(150 mm) underneath the check line to quantify runout.
  6. #25
    May 2011
    New Jersey
    2,989
    299
    1648
    Quote Originally Posted by john411 View Post
    The fuck are you talking about...who said anything about axles and what the hell is an exactness test bar? Put it straightforwardly under? Did you drink your breakfast, and I don't mean protein shakes?
  7. Likes Ox liked this post
  8. #26
    Feb 2014
    FL
    4,397
    13714
    5268
    Quote Originally Posted by plastikdreams View Post
    He's a spammer building cred/post count. Check his history. 3 posts, nonsensical, one about the stock market. Just report him and move on.
  9. #27
    Jul 2019
    Florida
    4,265
    4099
    816
    This is about 12,000 parts, everything should work from a bar, quickly and without problems.
    Charge them extra to have good round material and get feedback on it if the print seems to prove to you that you might get caught with a problem. Money gets them talking and on the level. They likely know the issue well if they have need of that many parts. That will get them to start talking about their realistic expectation.
    I think you should address the concern at this point since you are at a balk in this situation. Sorry I did not mention it earlier. Usually these things work out if not then you will just resent the extra time and expense which you think they need. Given you are at the mercy of raw bar stock material trueness right off the bat.
  10. #28
    Jul 2019
    Florida
    4,265
    4099
    816
    Regular off the shelf cold rolled bar is not straight, nor concentric. If you believe that than you are more the fool than originally led on. Centerless ground bar will be straight and concentric.
    If only a few are out of spec, throw em out and continue on.
    Thank you. At this point best to tell him to figure it out himself if he does not believe it.
  11. #29
    Jul 2019
    Florida
    4,265
    4099
    816
    Quote Originally Posted by Fancuku View Post
    No it is not.
    This kind of things bring on heavy drinking for hard headed bubble brains. Done. Would not have wasted five minutes on it if it were some hot shot complaining at a shop.
  12. Likes Fancuku liked this post
