Basic of 2-Axis CNC Lathe?
Results 1 to 2 of 2
    Apr 2019
    New York
    6
    Default Basic of 2-Axis CNC Lathe?
    For starters, stand back from welded steel or light-duty construction—you need a machine with a single-piece, 45° slant bed Meehanite casting as its base.
    The ways should be wide enough to support heavy cutting, and precision-ground and hardened for long-term accuracy.
    You’ll also need a programmable tailstock, a fast, heavy-duty turret, an industry-leading CNC control, and since you’re getting to be making many chips, make certain to settle on a machine with a strong coolant system and a chip conveyor.
    Dec 2012
    Se Ma USA
    1,736
    138
    950
    Somewhere on Earth a bug has died from the oxygen I wasted reading that.
  3. Likes VTM, TeachMePlease, npinson, Vancbiker, aj liked this post
