Anthonytn79
- Jul 25, 2017
Hi Guys,
Please recommend me a setup (less than $50k prefer)
I'm looking to produce titanium, titanium wedding bands (low quantity) may be 20/day. I've been searching for a newbie friendly cnc machine to make the process easier.
I've been playing around with a manual Sherline lathe and mill to cut grooves for titanium ring and drill holes for jewels. I would like to start making titanium ring from solid rods instead of modifying blanks like I've been doing. I sell about 8-12 rings/day so I don't need a really high end machine that can crank out hundreds of rings per day.
I have 0 CNC experience, so something newbie friendly that I can learn on the job would be great. I have a civil Eng. background so I can probably learn quick. I think it's similar to learning Java, or C++ or AutoCAD Civil 3D etc...
I have found ringtech.com machine videos and they work amazing for wedding bands. The software is very very noob friendly as well. All the profiles are pretty much preloaded and the user just change some parameters such as width, size, thickness, radius, etc... The downside is the $250k price tag. Since I'm not looking for such high end machine what would be a similar setup?
Right now I stock rings with difference styles (size 4 to 15 including half sizes, 30-50 rings each size) The cost of stocking 50 styles would be 150k+, so I thought with a CNC machine I can just stock titanium rods and produce the ring (style/size) based on customer request.
Example: If I get the Tormach 770MX when it comes out this winter and learn Pathpilot, can I create a profile for a ring style and save it and then later load it and just change the parameter for ring sizes / width / thickness?
How hard is it to program a curve interior cut for the comfort fit style?
Is it possible to find and pay someone to create those ring profiles? I can provide picture of existing styles I would like to be able to produce. They are mostly very simple flat or domed wedding bands with some grooves or holes for jewels, etc.
