Best Coolant - Best High Pressure Through Spindle Coolant
Results 1 to 9 of 9
    Feb 2019
    Georgia
    12
    Default Best Coolant - Best High Pressure Through Spindle Coolant
    I am getting a new machine and I want to know some opinions on your favorite coolants esp. High pressure through spindle coolant. I will be machining pretty much all the materials you can think of. Please be specific. I am looking at Blaser Synergy 735. Does anyone have this.
    May 2004
    2,507
    886
    1637
    Quote Originally Posted by Toolmaker84 View Post
    Speaking of specificity, maybe you could clue us in to what machine this is on and the type of filtration that will be used, and what exactly you mean by "high pressure". Are we talking 300psi or 2,000psi? Are you filtering to 1 micron or 20 micron?
    For what it's worth, at 2 micron filtration and 450psi, Oemeta Hycut has been flawless for us. No skin issues, doesn't smell like flowers nor does it smell like a skunk, easy maintenance, and it's the best cleaner in the shop.
  3. Likes Chazsani, 2outof3 liked this post
    May 2017
    Minnesota
    1,085
    1338
    730
    I'm using Hangstefers S787D in a VF-3SS with 1000PSI TSC. I usually cut 17-4 H900 and Ti6Al4V-ELI. No complaints. I change it out every six months but it never gets stinky.
    May 2004
    2,507
    886
    1637
    Quote Originally Posted by mhajicek View Post
    One of the things I like about Oemeta Hycut is that sump life is measured in years with no special maintenance. I don't even skim ours. I only had ours changed after our fire because it might potentially have an issue after sitting for 3 months. Which it didn't.
  6. Likes kevin66, Chazsani liked this post
  7. #5
    Sep 2014
    1,863
    1381
    1357
    Quote Originally Posted by [email protected] View Post
    Filtration is critical. if you filter the coolant through too tight a filter, the coolant can separate. Talking to not just the coolant manufacturers but the pump builders is key. Higher PSI means more heat and more chance to see coolant issues.
  8. #6
    Feb 2019
    Georgia
    12
    Thanks for the replies. It will be a 1000 psi system. From what I can tell it is a 2 micron filter.
  9. #7
    Mar 2019
    Tennessee
    5
    7
    Default Few Tips
    Congrats on the new machine, I know you're proud...
    Few tips. Coolant pressure and flow shouldn't affect most coolants. If you have a high-pressure pump, you could have some mechanical foaming issues if you have aeration.
    For aluminum and copper, you need to watch 2 things primarily. First is staining. Many coolants still have ingredients that will stain yellow metals and aluminum. Second, the nature of Aluminum makes it a more difficult metal to deal with from a lubrication standpoint.
    Fully-clear synthetics are usually very powerful products. However, I will caution that they're difficult to manage because the product is clear and thus harder to test in a refrac. I've seen people let it dip down under 3% and have rust issues because they didn't leave enough product in the concentration. If you run too much, you're going to strip all the paint off the machine and leave residues all over everything.
    I'd still run a clean-running semi-synthetic with some oil content, and I love clear, full synthetics. They're going to provide the lubrication you need in every application.
    Finally, some machine builders don't like full synthetics, very particularly Japanese and German machine tool builders. I'd check on this particularly so you don't have any warranty issues.
  10. #8
    Oct 2005
    15,557
    Quote Originally Posted by supertiger View Post
    Who do you rep for ?
  11. #9
    Mar 2019
    Tennessee
    5
    7
    I represent Bechem, the oldest German lubricant manufacturer.
