Best cutting life for cast aluminum tooling plate hogout? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21
    Jul 2008
    Milverton, Ontario, Canada
    551
    130
    214
    Quote Originally Posted by Upnorth4 View Post
    I know that this is an old thread but it might be of some value to revive it.....
    I’m machining cast aluminum blanks and just thought I would add this:
    Check the part for residual sand from the casting process.
    I have rough cast blocks I am machining and it has beaten the APKT inserts that I have been using for almost a year.
    The casting have entrained sand from the casting process and I suspect that is what caused the inserts to wear rapidly.
    I’m not sure what the best way to get rid of the outside layer of these blocks is.
    Could you hit them with high velocity walnut shell?
  2. #22
    Dec 2003
    poulsbo, wa, usa
    664
    29
    271
    I have changed most of my hogging to the TAS cutters from lakeshore ,,, I just ran 4k LBS of 6061 chips on a single 1/2" cutter and its still cutting just as good as new ... I like the TAS cutter but have tried there alum 3 flute finishing mills and went right back to YG1 Alu-Power mills ...
  3. #23
    Jan 2019
    Arizona
    432
    29
    146
    we used to cut that stuff all the time, we made the tool changers for the old arcoloc's series 10's and 100's. 34" dia 1.5" mic 6 plate with a ton of 4.5" holes in them and c-bores, best tool we found was a 2flute cheap normal carbide endmill then ran one as a rougher. no sence in paying a ton of money for a high dollar endmill that sand is going to eat the crap out of. Always got a great smooth finish about 63 finsh. every once in a while we would find a hollow air pocket.
    if I recall I was running at 6500 rpms doc was over .5 and the withd was around .300 on a 1/2" endmill on my fadals and 8500 for finish tool.
    when the finisher got dull we made it a rougher.
