I don't think the difference in tool wear would amount to a hill of beans. Think more in terms of process control. Let's say you were graphing your output. You'd put a control limit at the upper and lower tolerances. You'd plot your actual sizes. In a perfect world that would be a line halfway between the two limits, giving your process maximum room to wander. If you started to see some drift, you'd make a correction to get back to center. If the line started to get noisy, you might change out the tool, or whatever you determined was the cause.
