Best method for slotting aluminium?
gmc1724
Oct 24, 2013
United Kingdom
I have a job coming up that involves producing an enclosed 10mm wide slot through 20mm thick aluminum plate, the slots are approx 400mm long and there's about 300off to machine. Machine is a Mori Seiki MV-Junior and I'd like to keep the rpm to below 5000, any suggestions on tooling and method would be appreciated, I don't machine much aluminum.
Well, with an MV-Junior you're belt driven, correct?
If tolerance isn't really an issue I'd use a 10mm 2 flute UNcoated carbide end mill, and ramp down the center. You won't be able to go full depth and slot that with that machine.
HSS could even be an option given your RPM limitations.
Typically you'd go as fast as your spindle will allow when cutting aluminum.
I should just clarify one point, I'm not looking to break any records, I'm just looking for a stable process that can be left to nibble away on it's own.
10mm = 0.3937"
I would use a 3/8 endmill on the center line of the slot, then finish the walls with it if you need close dimensions and good finishes. You may be able to do the roughing in one pass with a 1" long endmill, your ratio is only 2:1.
Call ExKenna and order a 5/16x .88 LOC "streaker" (or comparable) brand endmill.
Run a high speed path at full depth, and a 5-10% radial stepover. Keep your (radial chip thinned) IPT around .001-.002 and you should blaze through the slots.
What fun is that?
While I'd be tempted in our machines to go full depth with a 3/8" tool, I know what kind of coolant flow I have with the flood coolant; I don't know how your coolant flow is.
And since you sound like you're okay with it nibbling away and taking a couple minutes longer than technically possible, I'd use a 3/8 tool down the middle in 2, maybe 3 passes just to be "safe". You want to avoid chips getting packed in the flutes. They can, and will, weld into the flutes if you don't have enough coolant to flush them out.
with a 3/8" tool going 5000rpm, lets say a 3 fluter (2 would be good, 4 is too many but you can use it) you could go about 30" inches per minute (about 800mm/min, 550mm/min for a 2 fluter) for the full slot down the middle (taking 2 or 3 passes of course) and that would be conservative
after going full slot down the middle, step out to finish the walls the last little bit at a bit faster feeds.
Some would say that's too slow, and they might be right, but it will work, and you probably won't break any provided your workholding is good and you have good coolant.
Just thought as I walked away, if you do want to go *a bit faster*, 1 minute saved on a 300pc job is 5 hours of cutting time. You could save a day of work just pushing this one tool a bit faster. Up to you.
And if Tom chimes in about how trying to save one minute of cycle time can cause 10 hours of fixing the machine, and how he has spent hours removing broken drills 10" deep into his 10000$ parts...
What fun is that?
with a 3/8" tool going 5000rpm, lets say a 3 fluter (2 would be good, 4 is too many but you can use it) you could go about 30" inches per minute (about 80mm/min, 55mm/min for a 2 fluter) for the full slot down the middle (taking 2 or 3 passes of course) and that would be conservative
So I have a budget of 18mins per slot on these, I know that's a lifetime but if I can get it down to half that without standing over the e-stop I'd be happy. Is the general consensus to use 2 flute or 3 flute? High helix? Carbide or HSS? The flood coolant supply is quite good and the machine is old but decently rigid.
Well that's a really lot of time for that operation :crazy:. I get 1/3 in^3/min. We can do better ;).
I'd consider a carbide corncob style of rougher in 3/8" size. At your 6,000 RPM and .002" chipload x 3 flutes, that's 36 IPM so a 2 depth cut toolpath would take 1 minute. Same speed and feed for the finish down each side and you are at 2 minutes.
Regards.
Mike
I just wanted to mention that if you take the speeds/feeds I mentioned above, I didn't convert my inches per minute to mm per minute right. should be around 800mm per minute when I said 80.
As someone else mentioned, you'd get that slot done in just a few minutes even if you take 3 passes and a finish pass.
Since you are RPM limited I would look for a tool that thrives off of feed.
I highly recommend the 3 flute Destiny DiamondBack 3/8" carbide rougher.
Then, as others have mentioned a fast finish pass on the sidewalls with a Destiny 3/8" 3 flute Viper.
With the Stealth Moly-S coating these are very hard to beat. Exceptional tool life and MRR.
Diamond Back S&F - Destiny Tool
X
depends on part shape. if part vibrates badly you might need to use more than one pass roughing. usually better to use end mills made for aluminum on aluminum. coolant helps gets chips out of the way and helps prevent chips sticking to cutter
obviously cost of part is a factor. if part moves in vise and is scrapped that can be expensive. many parts you use too much vise pressure it leaves vise marks which are unacceptable on part. also parts tend to bend or distort when vise extra tight. thats why often vise is often rechucked at lower torque before finish cuts
most take a later finishing cut for precision and sharper corners as rougher often has bigger radius on corners
