For people who use right angle heads on their VMC all day every day, what's your favorite brand of right-angle head?
I'm not talking about the occasional part where you switch the head in when you need it. We're looking for a quiet tool, long life, and consistent performance at 5000-6000 rpm, running night and day, 20 hours a day, semi-lights-out (just somebody to stop the machine if there's a problem). We have one right now we've been using for the past 3 years (though not at full capacity), and it's time for a rebuild. I'm pretty sure the bearings are shot. When we ramp up capacity, I'd rather not have to rebuild these every year if such a thing is possible.
The main problem I've had so far is noise. I'm not talking about a rattling noise or a "something wrong" noise; I just mean the tool is loud... it ran that way for 3 years and we made good parts. Nevertheless, it probably does shorten the life of the tool.
Some other considerations besides brand: Can I reduce the noise by getting a flange-mount head instead of a removable head with stop block? We don't need the tool change option, and I think it may add some rigidity to mount the head permanently. Also, I'm considering switching to an ER11 instead of an ER25 size. This would have a capacity of 10,000rpm instead of 6,000rpm. We don't need the 10,000rpm, but maybe it will help if I'm not maxing out the tool all the time. Will a higher-speed-rated tool run quieter than a lower-speed-rated tool, at the same 6k rpm speed?
Thanks for any help!
