Looking for a new lathe at the place I work when we get the new capital budget next year. We currently have a fairly old CNC lathe that is run only for making internal-use tooling. The current lathe still runs well most of the time, however if there is a problem there is virtually no support or information for fixing it (it's an Amera-Seiki TC-20, and if you search it, good luck finding more than 3 results that aren't a TC-2L). There have been two times that it was down for over a month while a machine repair company was troubleshooting, waiting on parts, fixing, and testing it. Also required multiple techs to come in and look at it, because no one knew anything about this particular lathe. Because of this we are looking to upgrade before it breaks down again.
What I am looking for is a 2 axis lathe, 20+ hp, 2.5" min bar capacity, 4000+ max RPM spindle, and 12+ position tool turret. I will also need some sort of chip conveyor or chip other removal. Current lathe has x-travel 5.19" and z-travel 14.17", which are each perfectly adequate for what we turn on it. The current lathe has a footprint of 90" x 63", and it would be ideal to stay close to that. We do have the ability to shift things around for more space, but not a lot more. I'd also like to keep the price at or under $30k.
Disclaimer: I am largely self taught on the current lathe that we have, so I don't have a lot of other knowledge beyond what I've encountered. Feel free to give me more direction if anything I've said doesn't make any sense.
TIA
TIA
