Big time noob needs help with Fadal EMC. - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 62
  1. #21
    Feb 2014
    Sunny South West Florida, USA
    3,315
    11430
    3712
    Quote Originally Posted by InspireCNC View Post
    Pay someone to teach me? No thanks. cnc machining is simple stuff. Figuring out specific hardware to use and learning the machines programing just takes time to figure out.
    I suggest you start a new username.
    Showing off an attitude like that here pretty much just guarantees that the knowledgeable people here (and there are lots, literal millenia of combined experience here) aren't going to take the time to answer your questions. And if you don't know how to mount a vise, you're going to have lots of questions.
    Good luck. You're going to need it.
  2. Likes mountie liked this post
  3. #22
    Apr 2020
    Illinois
    20
    Hello all, thanks for the advice. Fortunately for me this is easy stuff, for most it's not. It's just a matter of figuring out the small details and learning by asking and trial and error. So far I've been able to purchase proper hardware to clamp down the vise, buy the right retention knobs, wire my own harness from the rs232 db25 port to a rs232 9 pin on the computer, learn the controls and interface of the fadal, and finally started cutting a part. The first part I've cut is out of 304 stainless steel for xometry. I could use some advise on what feeds and speeds work well. I'm not getting enough tool life out of my bit. I'm using a TiAl coated 4 spiral flute 5/16 CR endmill. Cutting at about .0014 per tooth. Step over between 30-40 percent and depth is .125". At 4 IPM. Using plain old water for coolant for now. Tool will break after about 2 hours. Does this look right to you guys or can it be more effective.Attachment 285517Attachment 285516Attachment 285515
  4. #23
    Apr 2020
    Illinois
    20
    Quote Originally Posted by D Nelson View Post
    I’d like to see the men where he comes from.
    This is probably the most complicated job to do properly. I can’t think of anything that takes more knowledge
    Don
    You want to see men? You must be white to say something so xenophobic
  5. #24
    Apr 2020
    Illinois
    20
    Quote Originally Posted by TeachMePlease View Post
    Luck didn't build me my manufacturing business, my attitude did. I wonder how much help you've received in your life, I would laugh at that.
  6. #25
    Jan 2019
    Arizona
    901
    82
    326
    You be pretty "easy" for you to figure out
  7. #26
    Feb 2014
    3,315
    11430
    3712
    I've had lots of help. Here on the forum and in real life.
    I've also been humble and appreciative of that help.
    Change all your G1s to G0s, your program will run faster.
  8. Likes VTM, Bobw liked this post
  9. #27
    Jun 2018
    Idaho
    144
    35
    30
    Well 304 doesn't like just plain old water for coolant. You really need to switch to plain old RO water. That should double your tool life Immediately.
  10. #28
    Feb 2019
    New York
    104
    74
    If a used kurt vise exceeds your budget, it's not a business I would be pounding my chest about
  11. Likes Garwood liked this post
  12. #29
    Sep 2014
    Georgia
    602
    8
    109
    Quote Originally Posted by AJ H View Post
    No this guy is a pro. His Chinese vise is way better than your crappy Kurt....
    Hey guy by the way may you should try around 7k rpm that might help. If you machine can do it push it to 10k rpm.
  13. #30
    Sep 2010
    Oklahoma City, OK
    4,832
    855
    2001
    Quote Originally Posted by Ianagos View Post
    But you gotta use the G0 zero trick. G1's will keep the feed/tooth too low, don't want to work harden that SS.
  14. #31
    Sep 2014
    Georgia
    602
    8
    109
    Quote Originally Posted by Cole2534 View Post
    Oh yea that’s true. I forget sometimes but this guy probably already knew that man. This shits easy. Pretty sure he is gonna beat asd9100s numbers on Xometry pretty soon.
  15. Likes TeachMePlease liked this post
  16. #32
    Apr 2020
    Illinois
    20
    Im very proud of my business that I built from nothing and with no help. You couldn't do the same nor does anyone care about your lack of legacy. oh wait, you can afford a kurt vise, theres your legacy.
  17. #33
    Apr 2020
    Illinois
    20
    Quote Originally Posted by Delw View Post
    its been pretty easy to figure out so far. Im sure you struggle because youre weak and mediocre.
  18. #34
    Apr 2020
    Illinois
    20
    Theres lots of insecure men here that took too much pride in what they can do with a CNC machine that got so offended that i called it easy. Sorry but this work doesnt take a smart person to do, thats why shops hire non educated operators and high schools are teaching teenagers to be machinist as an elective, LOL. Its easy, Im sorry if that hurts your ego.
  19. #35
    Feb 2005
    9,211
    14799
    11014
    youre weak.
    I can honestly say that I appreciate the correct spelling of YOURE and WEAK,
    but you forgot the apostrophe.
  20. #36
    Apr 2020
    Illinois
    20
    Easy, you boys have fallen behind thats why.
  21. #37
    Apr 2020
    Illinois
    20
    Come on boys, If i say its easy, you should have agreed or atleast not attacked me for it. I guess its not for you but it is for this 15 year old girl, she doesnt even have a license to drive.
  22. #38
    Apr 2020
    Illinois
    20
    Quote Originally Posted by Bobw View Post
    Bob, its no longer a good rebuttal to spell check someone on the internet. That was cool 10 years ago.
  23. #39
    Apr 2020
    Illinois
    20
    You need lots of luck and lots of help. You think a mediocre skill takes smarts and talents. Youre offended by someone claiming mediocrity is easy. Youve been conditioned to be weak. Thats the truth.
  24. #40
    Jan 2015
    Missouri
    1,141
    217
    696
    So let me guess whipping something like this would be a cake walk for a guy like yourself
