another way that i used / was for custom combinations
when there are too many combinations, i simply write specific content :
- 0000 : means that all 4 operations will be executed in their default state
- 0302 : means that only 1st and 3rd operation will be executed in their default state, while 2nd operation will be executed in variant 3, and 4th operation will be executed in variant 2; depends
by pressing / i toogle between normal method and custom method, and entire program is recreated as desired
after a while i stopped using /, thus i stopped activating such behaviours from the control panel buttons, because too many keystrokes were required ( is faster to click a mouse or the touchscreen , than to press a key on the keyboard ); also, if control panel buttons are no longer required, than we can talk about remote control
in this way, the way a program performs is changed dynamically, without the need to write in advance a number of iterations, so to choose later from them
