Hi everyone. I'm running some Licon 5 axis CNC machines (machining cast). I have a boring tool that roughs and finishes with the same tool (4 sided cutter). The issue I'm having is the size I set the tool to is way under than what it finishes as. I set the tool to 66.85mm and It comes out at 67.2mm. I've checked the HSK100 tool for burrs/damage, I've stoned the face of the spindle (it's being held solid by the collet), I've tried just about ever speed and feed but nothing seems to work. I even swapped the spindle assembly and motor. Any ideas suggestions would be much appreciated because I'm at a loss as to why I can't correct it. Oh yeah, we use a lubrix misting system with lubricut cutting oil (on max mist setting)
Cheers,
-Jeff
Cheers,
-Jeff
