Boring bar chatter cure... I don't believe it!
JBNimble
Mar 17, 2019
I have read a couple times (on this forum) that loosening set screws on a boring bar can sometime cure stubborn chatter issues.
I have a very sturdy setup with a 3/4" bore bar with less than 3x stickout. We struggled with a persistent chatter issue that could not be cured with any combination of speed, feed or DOC. So, when I setup the same part again yesterday, I decided to try loosening all but the first set screw on the tool holder block.
100% fixed. Not only that, but I have varied the parameters wildly and now I cannot generate chatter with any conditions. So, I went to very heavy roughing passes and an ideal finish pass for a fast, perfect results on every part.
Simple solutions are not always intuitive.
Thanks to the random comments in prior posts for putting this idea in my head.
Your solution could have been found by the guy who forgot to tighten all his screws. Tightens the first one then gets called to the phone.
Comes back and has a nice day. Maybe it's a guess but I think what you did was change the resonant frequency. Would like to see a animated
video of before and after. You would think what you did was to make things worse. I'm going to try this one day.
Yes with resonant systems, changing stiffness to change the resonant frequency can be very effective. Changing mass can work too (e.g., securing a weight to the vibrating system).
There are many situations in machining where tightening can be over done creating less than stellar results, often caused by undertightening something and making scary noises and sometimes sparks too. It is often hard to find and maintain that sweet spot.
I forgot to fully tighten a cut off tool in my Doosan a few days ago. Results were not so pleasant. hahahaha.
But yea, sometimes putting some alum between the screw and the boring bar helps as well. I've seen bicycle tire tubes wrapped around big boring bars before.
I sometimes use a 2x4 and press it gently to a piece of metal that might vibrate. Like if it was in a vice and the ends were not as stable as the middle section.
Works pretty good in a situation that has few options.
Having only one screw tight is not something I think I would have tried, so thank you OP for sharing that experience.
It is the exact opposite of safety. So the decision is to risk a tool coming off a holder or getting a crappy finish.
I think that when you loosen setscrews from front to back to get the chatter to go away you should have more than one setscrew holding the tool.
I would still go for it if there was only one screw out of four tight, but I would be careful and take light cuts.
It's a fully captive round hole bar holder and the set screw is landing on a flat. The bar is not going anywhere. I've maxed out the speed, feed and DOC according to the ISCAR insert parameters and it makes a beautiful swoosh sound.
I always only use one set screw. Typically it's the one on the end or furthest from the insert.
Brent
Interesting. I am using the one closest to the insert. I suppose it would be possible to cure different problems by tightening different setscrews. I'll keep that in mind.
I verify by tightening the rest and see if the chatter comes back.
I think what you effectively did was lower the resonant frequency so that you're cutting well above it.
I learned about that from someone much smarter than me, years ago.
Says the guy who just said he holds a piece of 2x4 against the part being cut in a (presumably) CNC machine with the door open... :D
I believe Jashley mentioned using electrical tape or something under the holder to get some form of "de-vibe" action. dampening of sorts...?
So the only thing my 12CK does for the last decade or more is enlarge an over 2 inch bore by an inch over .15 deep. Total hack work,not fussy.
Use a brazed carbide cause cheap.
Chattered up a storm
tried everything adjust tool height faster slower feed[feed is only limited by grip of jaws on the part]
solution?
run the Aloris loose.
I always meant to ask for advise here but I was going to give it one more go at finding a solution first
So maybe that is the solution
