Boring bar chatter cure... I don't believe it!
Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Mar 2019
    CANADA
    Ontario
    41
    24
    Default Boring bar chatter cure... I don't believe it!
    I have read a couple times (on this forum) that loosening set screws on a boring bar can sometime cure stubborn chatter issues.
    I have a very sturdy setup with a 3/4" bore bar with less than 3x stickout. We struggled with a persistent chatter issue that could not be cured with any combination of speed, feed or DOC. So, when I setup the same part again yesterday, I decided to try loosening all but the first set screw on the tool holder block.
    100% fixed. Not only that, but I have varied the parameters wildly and now I cannot generate chatter with any conditions. So, I went to very heavy roughing passes and an ideal finish pass for a fast, perfect results on every part.
    Simple solutions are not always intuitive.
    Thanks to the random comments in prior posts for putting this idea in my head.
    Mar 2009
    6,115
    115
    1201
    Your solution could have been found by the guy who forgot to tighten all his screws. Tightens the first one then gets called to the phone.
    Comes back and has a nice day. Maybe it's a guess but I think what you did was change the resonant frequency. Would like to see a animated
    video of before and after. You would think what you did was to make things worse. I'm going to try this one day.
  3. Likes Homebrewblob liked this post
    Sep 2018
    Virginia
    12
    6
    Yes with resonant systems, changing stiffness to change the resonant frequency can be very effective. Changing mass can work too (e.g., securing a weight to the vibrating system).
    Apr 2020
    1,245
    1086
    444
    I’ve done the “Wrap the bar in a piece of lead” thing with good results.
  6. Likes johansen liked this post
  7. #5
    Aug 2007
    Idaho
    2,472
    1044
    1322
    There are many situations in machining where tightening can be over done creating less than stellar results, often caused by undertightening something and making scary noises and sometimes sparks too. It is often hard to find and maintain that sweet spot.
  8. #6
    Sep 2018
    Virginia
    12
    6
    Having only one screw tight is not something I think I would have tried, so thank you OP for sharing that experience.
  9. Likes steve-l liked this post
  10. #7
    Nov 2005
    Illinois
    2,267
    247
    2189
    I forgot to fully tighten a cut off tool in my Doosan a few days ago. Results were not so pleasant. hahahaha.
    But yea, sometimes putting some alum between the screw and the boring bar helps as well. I've seen bicycle tire tubes wrapped around big boring bars before.
  11. Likes Cycle1000 liked this post
  12. #8
    Oct 2020
    PORTUGAL
    121
    21
    46
    Quote Originally Posted by fmari --MariTool- View Post
    I sometimes wrap a bike tube around the work, if it's the sort of shape that rings easily.
    The difficulty is getting the tube to stay there and not be in the way of anything.
  13. #9
    Jul 2013
    Indiana
    3,420
    5023
    1756
    I always only use one set screw. Typically it's the one on the end or furthest from the insert.
    Brent
  14. #10
    Mar 2009
    6,115
    115
    1201
    Quote Originally Posted by jwmelvin View Post
    I sometimes use a 2x4 and press it gently to a piece of metal that might vibrate. Like if it was in a vice and the ends were not as stable as the middle section.
    Works pretty good in a situation that has few options.
  15. #11
    Nov 2004
    RC, CA
    2,194
    228
    473
    Dad had a bar ground from a long 3/8 square bit. He hung the carriage lock wrench on the tail end of it to kill the chatter.
    'But, that's completely on the other side of the toolholder and screws. WT ...'
  16. #12
    Mar 2009
    6,115
    115
    1201
    It is the exact opposite of safety. So the decision is to risk a tool coming off a holder or getting a crappy finish.
    I think that when you loosen setscrews from front to back to get the chatter to go away you should have more than one setscrew holding the tool.
    I would still go for it if there was only one screw out of four tight, but I would be careful and take light cuts.
  17. #13
    Mar 2019
    CANADA
    Ontario
    41
    24
    Quote Originally Posted by rons View Post
    It's a fully captive round hole bar holder and the set screw is landing on a flat. The bar is not going anywhere. I've maxed out the speed, feed and DOC according to the ISCAR insert parameters and it makes a beautiful swoosh sound.
  18. Likes mhajicek liked this post
  19. #14
    Mar 2019
    CANADA
    Ontario
    41
    24
    Quote Originally Posted by yardbird View Post
    Brent
    Interesting. I am using the one closest to the insert. I suppose it would be possible to cure different problems by tightening different setscrews. I'll keep that in mind.
  20. #15
    Jun 2008
    Roanoke, VA
    786
    203
    311
    Quote Originally Posted by JBNimble View Post
    I verify by tightening the rest and see if the chatter comes back.
  21. #16
    Feb 2012
    1,600
    979
    1815
    I think what you effectively did was lower the resonant frequency so that you're cutting well above it.
    I learned about that from someone much smarter than me, years ago.
  22. Likes johansen liked this post
  23. #17
    Feb 2014
    FL
    4,307
    13554
    5134
    Says the guy who just said he holds a piece of 2x4 against the part being cut in a (presumably) CNC machine with the door open...
  24. Likes mr.greenman liked this post
  25. #18
    Nov 2014
    Florida
    6,245
    2485
    3096
    I believe Jashley mentioned using electrical tape or something under the holder to get some form of "de-vibe" action. dampening of sorts...?
  26. #19
    Sep 2002
    People's Republic
    6,049
    720
    3737
    So the only thing my 12CK does for the last decade or more is enlarge an over 2 inch bore by an inch over .15 deep. Total hack work,not fussy.
    Use a brazed carbide cause cheap.
    Chattered up a storm
    tried everything adjust tool height faster slower feed[feed is only limited by grip of jaws on the part]
    solution?
    run the Aloris loose.
    I always meant to ask for advise here but I was going to give it one more go at finding a solution first
    So maybe that is the solution
  27. #20
    Nov 2004
    RC, CA
    2,194
    228
    473
    With the holder just hanging on the dovetail?
    I've had mine either vibrate loose ... or I forgot to tighten it ... and it cuts just beautiful. Insert OD turning tools mostly. 4140PH, 416, maybe some alum. Holds dimension too. Weird.
