Boring bar chatter cure... I don't believe it! - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21
    Mar 2019
    CANADA
    Ontario
    41
    24
    Quote Originally Posted by Nmbmxer View Post
    I verify by tightening the rest and see if the chatter comes back.
    Did that. It did.
    BUT, on my next production run I needed the bar out farther to about 4xD. Tried with one set screw and it was awful. Tightened them all... beautiful.
  2. #22
    Jan 2007
    Flushing/Flint, Michigan
    10,430
    603
    8464
    Quote Originally Posted by JBNimble View Post
    Did that. It did.
    So on one job one screw good and all tight bad, on another one screw bad and all tight was good?
    Add the front or back screw as what works.
    How does one choose? What the heck is going on here? It has to be more than just simple resonance and sing frequency.
    Bob
  3. #23
    Sep 2018
    Virginia
    12
    6
    Bob
    I believe the idea is moving the bar’s resonant frequency either above or below the excitation frequency from the cut. So adjusting machine parameters can affect the excitation frequency and adjusting bar clamping will affect the resonant frequency. It should be a fairly narrow peak that one wants to avoid, so either direction can work.
  4. #24
    Sep 2002
    People's Republic
    6,049
    720
    3737
    Quote Originally Posted by wesg View Post
    With the holder just hanging on the dovetail?
    I've had mine either vibrate loose ... or I forgot to tighten it ... and it cuts just beautiful. Insert OD turning tools mostly. 4140PH, 416, maybe some alum. Holds dimension too. Weird.
    Yuh, weeeeeeaaaad
  5. #25
    Jan 2003
    UK
    882
    471
    446
    Any oscillating system has a 'Q' (or goodness) factor. The higher the Q the less losses and it's easier to maintain oscillation.
    What you've done is to lower the Q.
    The old blacksmiths trick of wrapping a chain or heavy rope around his anvil to stop it ringing is exactly the same principal.
    The WW2 Japanese Zero fighter plane had fluttering flaps at high dive speeds iirc that they added weights to on the leading edge and lowered the Q to cure the problem.
