Boring of a long, small tapered hole - Page 4
Page 4 of 4 FirstFirst ... 234
Results 61 to 64 of 64
  1. #61
    Nov 2013
    Utah
    4,203
    1145
    2300
    Aland Islands are Holland.
  2. #62
    Dec 2015
    Illinois
    344
    110
    187
    Wikipedia says Finland.
    Aland Islands - Wikipedia
  3. Likes litlerob1 liked this post
  4. #63
    Jun 2012
    Michigan
    9,673
    3282
    3462
    Regarding Ox's post #59
    A journeyman Blacksmith (Bob Duda) taught me a trick for hand grinding a part.
    You blue and it up with blue or just a marker then you carefully remove the blue and some stock in the manner you wish to remove stock, using the same number of grind slashes to each side or in the case of a cutter to each flute..blue again and grind again...surprising this works and the part stays near constant to center or size very well..
    *Yes OX's spin and grind would be the better way with having a spin fixture.
  5. Likes Nmbmxer liked this post
  6. #64
    Mar 2019
    Vermont
    I worked in two reamer shops and it seems like a reamer would be your best choice,it could be ground on an od grinder in very little time
